Soundblaster player
First post, by JayAlien
Hi, I haven't had much luck googling this - I was wondering if there is a DOS based player that can play music on Soundblasters, along with a file format that music can be stored in. I'm thinking similar to a .mid file for a windows based midi player, but DOS based either for FM synthesis, or for the later EMU synths. The Adlib Gold can do this with the Juke Box gold and the .RL2 format, anything similar for Creative?
Thanks,
J
386sx25 SBP2 2M
P75(486) SB16 8M
P133 S3 Vir DX A64g 32M
P233MMX R128Pro A64 64M
Pii400 TNT2 Live! 128M
P3-1G V5 M80 256M
P3-1.4G R8500 A1 256M
A3200 9700Pro A2 512M
X6800 X850XT A2ZS 1G
E8600 X1950XTX A4pro 2G
QX9650 3870 Xfi 2G
i7-975 GTX570 Xfi 3GB
Reply 1 of 5, by dionb
There's quite a lot out there, but it mainly sounds like you're getting your terminology mixed-up which is why you can't find it.
When speaking of "Soundblaster", people generally understand the Sound Blaster digital audio standard in its various versions, which is not about synthesis.
You're saying you're looking for something to play MIDI in DOS with either FM or EMU synthesis. That's something quite different, even if there were Sound Blasters that could do both, as well as their native digital audio.
I have the feeling this comes closest to what you're looking for, but searching for "DOS FM MIDI player" gives quite a few additional options:
PX Player: play MID and XMI files under DOS
Reply 2 of 5, by JayAlien
Well the only thing that may not have been clear is perhaps I should have said OPL instead of soundblaster. My mention of Midi was purely to provide an analogy - I'm not looking to play midi files natively on an OPL device.
Ideally I'd be able to download OPL game music and play the audio, without having to load the game. Almost like a SIDplayer on a C64.
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
Reply 3 of 5, by enaiel
JayAlien wrote on 2021-12-10, 22:56:
I think what you are looking for is SBVGM. It's a VGM player for DOS. You can download the DOS OPL game music as VGMs from VGMRips. Hope that helps!
VIA C3 Ezra-T 1.0GHz / MSI MS-6368 / Voodoo2+ViRGE GX / SBPro2+YMF744+AWE64 / MT-32+SC-50
Pentium III-S Tualatin 1.40GHz / QDI A10T / Voodoo3 3000+GF4 Ti4200 / Audigy+AU8830
Reply 4 of 5, by FreddyV
You can Check my player, Mod Master XT, there is a Thread for it in Vogons.
It can play .VGM and various other OPL Based file format.
Reply 5 of 5, by JayAlien
Thanks for the replies, I'll give the recommended players a try!
386sx25 SBP2 2M
P75(486) SB16 8M
P3-1G V5 M80 256M
QX9650 3870 Xfi 2G
