First post, by mt777
When I get next one MFM drive then using XTIDE-CF I make a backup of content then wipe drive to put fresh DOS + utils.
So I initialize disk, create partition and always the same problem - can't set active partition as system is already booted from the first drive (XTCF).
How to bypass? Without booting from floppy.
Reply 1 of 1, by bakemono
You have to use something like Norton Diskedit or a sector editor, or maybe DEBUG if you are a 1337 haxx0r...
Load up sector 0 (MBR) and then change the byte at offset $1BE from 0 to $80 to make the first partition 'active'
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
