Jet Fighter II
First post, by Pan
Has anybody had any luck getting Jet Fighter II to work under Dosbox? It just seems to freeze before entering flight no matter what I do. I suspect (this may be weak) that it is making an attempt to access some memory (possibly video) that is unavailable. I believe this is true because I used to have to clean boot to get it to work when I played it on a native system.
Regards,
Pan
Reply 1 of 6, by adrianebrown
hi,
if anyone has the configuration settings to actually get it running then please could you post them.
would be very grateful.
Reply 2 of 6, by Pan
It seems impossible to get the game working under the current Dosbox version. I think the game tries to access some video memory that Dosbox does not emulate. The game does work under QEMU and Bochs but unfortunately very slowly, since those environments aren't designed for games.
Reply 3 of 6, by HunterZ
It might work with some of the CVS builds floating around that have experimental emulation of various SVGA chipsets.
Reply 4 of 6, by vasyl
No, that game is not SVGA. It runs in VGA but has even support for CGA. When run in debug build it complains a lot about unimplemented interrupt 6 and unimplemented opcode F. It is possible that those are secondary problems and something else triggers them. Well, looks like prime candidate for "games that don't work" thread.
Reply 5 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
hmm try disabling sound.
but I agree to vasyl. nice debug candidate.
Water flows down the stream
Reply 6 of 6, by Pan
Disabling sound seems to have no effect. On my current copy of Dosbox, it seems to alternatively either freeze or exit with the error "Exit to error: CPU:GRP5:Illegal Call 7".
I'll add the game to the broken thread along with another one I noticed.
