First post, by GabrielKnight123
I need to install Windows 98se on a motherboard with Sata DVD and Sata HDD (Asus P4S800-MX SE motherboard) but booting from the 98se CD cant load the CD rom driver it says CD drive not found is there a driver for Sata? Ive booted with a floppy and used SFDisk to format the Sata 320GB HDD I guess I have to make the HDD bootable with system files copied to it then edit autoexec.bat and config.sys to point to a Sata CD rom driver and boot to the C drive then install from the 98se CD. My Bios is set to use Sata controller in native not IDE or Raid.
Reply 1 of 4, by Repo Man11
With my Aopen i865 Gm-7n I can boot from the Win98 CD with a SATA optical drive and install to a SATA SSD by setting the SATA ports to "SATA Only" which sets them to "Legacy mode." If you don't have a bootable Win98 CD (OEMs were bootable) you can get one from a site called Winworldpc.
Reply 2 of 4, by GabrielKnight123
I would but my motherboard does not have sata only or legacy only disabled, native and raid so I tried GCDROM.SYS as a driver which works with Sata DVD drives but now I get a freeze somewhere during the install and a Windows 98 picture, I'm going to try "legacy os" enabled in CPU settings after I swap back the Sata drives I'm trying IDE atm and after install it can't find the DVD drive to finish installing
Reply 4 of 4, by Repo Man11
GabrielKnight123 wrote on 2021-12-28, 14:25:
Copy the Windows 98 CD to the hard drive. http://www.windowsreinstall.com/win98/install … dexfullpage.htm
