Minecraft on pentium 1
First post, by Sphere478
It’s running!!!!
Hahah
System specs:
XP sp3
Java 6 update 00
Launcher 1.6.1
Dual Pentium 1 MMX 233mhz 66fsb
512mb 60ns simm memory
Geforce 4 pci
Promise tx4 sata II 300
256gb ssd sata
Usb audio
I’m getting a Massive 1fps or so 🤣. 🤦‍♂️
Which is actually a lot worse than halo CE which is actually almost playable. Or rather, actually is becaue I’ve completed levels on this in halo.
Sphere's PCB projects.
Reply 1 of 4, by TrashPanda
"Your scientists were so preoccupied with whether they could, they didn't stop to think if they should."
-Iam Malcom
I think this quote sums this up perfectly 🤣
Reply 2 of 4, by Sphere478
TrashPanda wrote on 2021-12-30, 08:05:
-Iam Malcom
Another dude on discord did it on a pentium 90😂
Reply 3 of 4, by TrashPanda
Sphere478 wrote on 2021-12-30, 08:55:
-Iam Malcom
Dare you to try a 486..you know you want to, that challenge gauntlet needs to be picked up 😜. (Can be any class of 486, ill let you decide which one you want to tackle)
Reply 4 of 4, by leileilol
I don't have minecraft but i've done minetest on P2 + PCX2 before ages ago when that was still SDL1 and didn't do much advanced extension use (enough to work in the Techland SGL MiniGL). Ran in the 20s when in a cave and had problems loading textures due to the 32x32 minimum so it resized everything up
