First post, by Rogue Martyr
Rogue Martyr
Offline
Hi there,
i was trying to install ZPC throught dos box but:
i mounted the drive correctly however when i try to run SETUP.EXE in the root directory it slaps a little 'win' in front of it when i press enter and then says unknown command: win. But i didnt type win!!! what gives?
has anyone had ZPC running on XP thru dos box or other means?
peace,
Rogue Martyr
