First post, by AaronS
Hi, I am looking for a thin client for 98SE (well the IGEL H700C is on the larger side I suppose) however from the looks of it it can potentially house a PCI GPU, wondering if anyone has any experience with it:
https://www.parkytowers.me.uk/thin/Igel/ud/ud5/H700C/
Wanted to ask before picking one up.
Thanks.
Reply 1 of 3, by Horun
Googling trying to run Win98SE leads no where good on the IGEL's. https://www.parkytowers.me.uk/thin/Igel/ud/ud … 00C/win98.shtml
If it wont run on a M300 doubt it will run on H700....
Maybe a Wyse VX0 ?? https://www.parkytowers.me.uk/thin/wyse/vx0/win98.shtml
Reply 2 of 3, by luk1999
If you want to use PCI card look for `Fujitsu Siemens Futro S400`: https://www.parkytowers.me.uk/thin/Futro/s400/
It has the same CPU and chipset as HP T5720 (tested by Phil) but it is IMO a better choice because:
* Case is big enough to install one of these chinese GeForce FX5500 PCI
* You can install CF card inside, additional adapters are not needed (16 GB Sandisk card didn't work for me, but 4 GB Transcend was fine)
CPU performance is on level with P3 or Athlon 1100, so it should be more than enough for games released till 2002/3.
P4 3.4E, P4C800-E Dlx, 1 GB, X800 PRO 256 MB, SB Audigy, XP SP2
A1.4, A7V133, 512 MB, R8500LE, FM801, ME
P3 600, AX6BC, 128 MB, GF2 PRO 64 MB, ALS100+, 98SE
K6/266, MS5149, 64 MB, Virge 4 MB, V1 4MB, ESS1868, 95 OSR2
Reply 3 of 3, by Mitchellin
AaronS wrote on 2022-01-08, 22:51:
Hi, I am looking for a thin client for 98SE (well the IGEL H700C is on the larger side I suppose) however from the looks of it i […]
Thanks.
I've installed win98 on it, however I've experienced some issues:
1. integrated graphics driver was not working for me. Nothing else but direct3d worked, even that was buggy, so I had to use a different PCI gpu. Which btw, has to be low profile because the heatsink of the cpu is rather prohibiting
2. weird interrupt issues because I used a microdrive, philcomputerlab did a video about these. Literally sound would hang every few seconds, had to use CF cards instead.
3. no drivers for integrated sound, so you'll need a usb souncard with a simple DAC that win98 can understand. I used a Sabrent one, worked realtively okay.
The unit is more suited for a win2k build, let's face it.
Main: i3 10100f, rx5600xt, Radeon 7000/SbLive. Dual Win10/Win98 boot.
Retro Win98 PC: Pentium 3 500mhz, Voodoo 2/GF4ti.
MiniPCs: Shuttle XPC SN41G (winXP/98), Iwill ZPC64 (winXP/98), Igel M340C (win7).
And some laptops.
