First post, by Megantonneke
For 286 build centred around an Ilon M-209 motherboard with a Harris CS80c286 20Mhz CPU, I was looking for a system case and came across this Heavy-duty Intel branded case (See bottom case on the photo below with a Laser 286/2 on top, for comparison of its oversized dimensions).
Has anyone seen this type of case/system before and have any info?
The case has Intel branding on the back with a product number and serial, but an extensive internet search did not uncover any info.
It has a 220W TEAPO Electronic Corp PSU, produced March 1990, with an Intel part number 108697-008. This type of PSU alone I also found on several 2nd hand site listings.
Besides the high wattage, the case has also a 9-10 inch fan on the front, Globe Motors D47-B10A-O4W2-000.
Clearly some heavy-duty system. There is also a label on the back that makes me believe that this system was maybe part of monitoring and control system for a sugar refinery.
The word "SUIKER" in the top right corner is the Dutch word for sugar.
The screws to take the cover off the case are also of a type I have never seen before.
Also, the drive bay covers have a special design where part of the cover goes over the front bezel of the case.
There is copious space inside and mostly build-in stand-offs.
