First post, by SoDaR2005
Ok so i have tried to play both Flashback and Shadow Warrior and both are so slow they are practically unplayable. Now, in Flashback if i turn the Music OFF (by running install.exe) it seems to sort itself out, but its not the same without music. Now i have had Flashback running with both SFX and Music absolutely fantastically BUT now it just seems to be dog slow when i turn Music ON ... why does it do this? I have had the game working perfectly with Music ON then it decided to slow down on me for no apparent reason whatsoever.
One time it worked and now it does not? Can someone tell me how to sort this problem out? And yes, with Music ON it does not go anybetter when i so called "overclock" the program, heck i have had it over 20000+ and it makes no difference whatsoever. Shadow Warrior is the same, whats the point in playing them with no music ... it's not the same.
Any ideas?
DFI Lanparty NF4 UT Ultra-D Motherboard;
AMD Athlon64 3500+ Winchester @ 2.6GHz;
1.0GB Corsair TwinX PC4400 (DDR550);
256MB MSI nVidia GeForce 6800GT PCI-E;
Windows XP Professional with Service Pack 2.
