First post, by Bama_38
I am trying to Use a program called Quick Menu III with DOSBox 0.63 and it works fine but I want to start DOSBox with the command line option -c "mount a a:\ -t floppy". I also start Dosbox mounting my CDROM's and Harddrives and then start a BAT file that starts Quick Menu III. Everything works fine except for the floppy which alway says there is no disc in the drive.
If I type this mount command for the floppy from a strait Z: prompt it works fine and even lets me look at the empty drive with "DIR" and says no files found. But in a command line I always get a pop up window saying there is no disc in the drive with a Retry Button and a Cancel Button and another button.
How do I get around this so that I can have an A: Drive in Quick Menu III?
Thanks........ 😎
