First post, by 386SX
Hello,
I'd like to ask your opinion finding the absolute best VGA output quality card compatible with AGP 1x/2x. I can see as often seen in the past that the G450 improved the already great G400 main output and the G550 probably even better. In your opinion, later cards did reach their analog signal quality and which one? Or maybe the Parhelia AGP card should be the obvious choice, but with the DVI to VGA adapter is it the same thing?
I've to say that compared to the usual other choices, these cards surprise me every times I test them for their analog output quality already and I wonder if there were better ones or the DVI outputs changed the logic we were used to compare final monitor quality (even on LCD, I'm sure CRT would benefit even more).
Thanks
