First post, by Geofand26
Yesterday I was installing a HDD when my PC Chips m577 motherboard died. It looks like a capacitor/resistor (?) leaked. On the board it's C21 but had a black 0(zero) on it like a resistor. I don't know what it is and what to actually buy for a repair. Can someone help?
137.82 KiB
978.19 KiB
Reply 1 of 30, by Sphere478
0 stands for 0 ohms
You should be able to solder it shut
Best I can see, that pad is set up in a T configuration to where you could put the link in one of three ways, or it ‘s meant to hold a link or a three legged component of some type, my bet is it’s set up as a switch, and that bridge is the one the designers chose. (Leave it that way)
But yeah, a solder bridge would replace that.
But I think your problem may be elsewhere, because, how exactly do you burn out a 0 ohm link, with 0 ohms the energy is going elsewhere.
I’m thinking the link may still be 0ohms (test it)
And that something else or just the capacitor is shot.
Sphere's PCB projects.
Reply 2 of 30, by Doornkaat
That's a 0 Ohm resistor. It's like a soldered jumper.
The silk screen marking is probably 'D21' (instead of C21) and referrs to a diode that may be installed in its place. (There's a third solder pad above the resistor and three legs are marked.)
There's probably another fault on this motherboard since it is not likely (though not unthinkable) that a resistor like that just goes up in flames.
Reply 3 of 30, by Geofand26
Doornkaat wrote on 2022-01-28, 08:49:
Its C21 for sure and the third pad isnt used for anything at least from what i can see. There wasnt anything else that popped or exploded of fried anywhere on the board. Could be the bios chip cuz its nearby. Gonna take it to a local repair this afternoon(in my country) and will see what he has to say. If he cant do anything i will try to just remove it and put a blob on it
Reply 4 of 30, by Geofand26
Sphere478 wrote on 2022-01-28, 08:47:
0 stands for 0 ohms […]
0 stands for 0 ohms
What do you mean by "the capacitor is shot"?
Reply 5 of 30, by TrashPanda
Geofand26 wrote on 2022-01-28, 09:06:
0 stands for 0 ohms
In the great words of John Cleese
"I'll tell you what's wrong with it, my lad. 'E's dead, that's what's wrong with it!"
https://www.youtube.com/watch?v=z9SMUzj-_4Q
Reply 6 of 30, by Doornkaat
Geofand26 wrote on 2022-01-28, 09:01:
Its C21 for sure
Not to be a dick but it isn't.
    239.82 KiB
Reply 7 of 30, by TrashPanda
Doornkaat wrote on 2022-01-28, 09:20:
Its C21 for sure
I shouldn't but im laughing right now cause you are factually correct That's clearly not a C, I cant help but hear that in Johns voice.
Ill show my self out.
Reply 9 of 30, by Doornkaat
Geofand26 wrote on 2022-01-28, 09:24:
Its C21 for sure
It got burned yea you are correct sorry for wrong info
No worries! 👍
Reply 10 of 30, by Geofand26
Just checked under the bios chip and i can vaguely see a blacked(burned?) trace. Probably killed the bios chip. Gonna remove the socket and see what i can do about the trace. Can i flash a new bios on an eprom chip or do i have to use something else?
Reply 11 of 30, by TrashPanda
Geofand26 wrote on 2022-01-28, 09:28:
You can if you can get hold of a blank eprom thats the same size as the one in there, it also possible the old bios is ok but the burned trace prevents it from working, keep hold of it and try reading it in a programmer, if you can read it fine and it doesnt look corrupted then keeping it as a spare/backup would be best.
Reply 12 of 30, by Sphere478
0 stands for 0 ohms
I assume that’s where all the gooey stuff came from.
Reply 13 of 30, by Doornkaat
It'd make sense if the EEPROM was defective that it would draw more current than the resistor could handle.
If the trace and socket are ok a new EEPROM with BIOS on it should do the job. I don't think you're likely to cause more damage by trying it out. Good luck! 😀
TrashPanda wrote on 2022-01-28, 09:22:
Its C21 for sure
Yeah, that'd fit right into the dead parrot sketch! 😆
Reply 14 of 30, by Sphere478
Am I the only one taking about the capacitor? Desolder that capacitor and check it for short.
Yeah, I see that burnt trace, I bet that capacitor did it, suspecting bios is fine. Replace cap and link and clean it up and maybe you are good to go?
Reply 15 of 30, by Geofand26
Thanks for the answers. I cant troubleshoot any further for now so after a few hours i will write back with results. You helped me more than most repair shops which just tell me "its too old so i wont even diagnose it" so again thank you so much!
Reply 16 of 30, by Sphere478
Geofand26 wrote on 2022-01-28, 09:40:
Those are called excuseshops.
You mentioned this happened while upgrading hard drive?
Did you plug cable in wrong?
Reply 17 of 30, by Doornkaat
Sphere478 wrote on 2022-01-28, 09:40:
There are two traces leading away from the burnt resistor. The trace leading to the capacitor is fine while the one leading to the EEPROM socket is burnt. Because of that I would suspect the short to be caused by the EEPROM, not the capacitor, even though you are right in that old electrolytics are never not suspect. 😅
The grime is probably burnt resistor and solder mask.
Fingers crossed, hope you get it fixed! 😀
Reply 18 of 30, by Sphere478
Doornkaat wrote on 2022-01-28, 09:45:
There are two traces leading away from the burnt resistor. The trace leading to the capacitor is fine while the one leading to t […]
This is the one I suspect
Reply 19 of 30, by TrashPanda
Sphere478 wrote on 2022-01-28, 10:13:
Looks great from above but needs to be removed to check its butt, sneaky caps like to leak from below.
