First post, by Grayshazzle
Just trying to replace it, I just want to know the exact size/common PC type. Thanks.
    1.43 MiB
    854.46 KiB
Reply 2 of 4, by Grayshazzle
snufkin wrote on 2022-02-01, 09:38:
Looks like one of the standard LED sizes, as in standard everywhere, not just PC. 5mm diameter? Check the sizes against the diagram here: https://www.make-it.ca/5mm-led-specifications/
Thank you 👍😀
Reply 3 of 4, by wiretap
Yep, 5mm. Grab an assortment so you have plent of spares and build some other neat LED projects.. https://www.amazon.com/Cylewet-Emitting-Highl … /dp/B01N4JA54A/
My Github
Circuit Board Repair Manuals
Reply 4 of 4, by Grayshazzle
wiretap wrote on 2022-02-01, 17:13:
Thank you so much!
