First post, by Errius
- l33t
If a directory contains the following files:
BAR.FILE
FOOBAR.FILE
then DIR BAR.* will only find the first, as expected. However if the files are
FILE.FOO
FILE.FOOBAR
then searching DIR *.FOO finds BOTH files. This behavior is also present in Windows 98 SE, and I assume in all other Windows versions since 95.
(This does not happen if files are
B.C
AB.C
and
C.A
C.AB
in which case DIR B.* and DIR *.A have the expected results.)
"AI Requires Proof That You Are Human"
