Playing around with sound under dos 6.22
First post, by octopus
Hi all,
I'm playing around with a couple of sounds cards under dos.
Vogons has been a superb help so far, I'm reading and learning a lot.
I couldn't find a topic where it would make sense to add my story, so I've decided to start a topic.
If this is not according to the ways of the board, please let me know.
So anyway, let's start (sound)blasting. I trying to work out how to get soundblaster compatibility in MS-DOS 6.22. I have a Windows 98 and a Windows XP machine that work just fine, the challenge is in the Dos part.
What am I using:
Mainboard: FIC PA-2005, VIA chipset. Alternate option is a p51430vx v2.0 with an Intel chipset, but so far I've been unable to get a peep out of that. The FIC gives me some sounds, so I've decided to work with the FIC for now.
Sound cards: I have four options.
1. Avance Logic ALS120 ISA card
2. Soundblaster CT4810 PCI card
3. Yamaha YMF724 PCI card
4. Diamond Edge 3D - this is a graphics and audio combo PCI card. I try to avoid using it. Only mentioned to be complete.
The results so far:
1. ALS120:
BIOS detects the card as a PNP Audio device.
I'm using the W95_120 installation from the VOGONS driver archive, withe the Dos installation.
ALS3.INI is configured as follows:
SB16Base=220
SB16IRQ=5
SB16DMA8=1
SB16DMA16=3
MPU401=ENABLED
MPU401Base=330
MPU401IRQ=9
A4INIT runs just fine, the card is found and initialized. No errors.
However, when running anything that should have sound, I get nothing from the speakers.
For instance: Biomenace detects Soundblaster compatibility and then goes silent.
On the other hand: Prince of persia goes straight to speaker sound.
This leaves me thinking that either the card is dead, or something is configured wrong.
Any thoughts?
I'm using the SoundBlaster PCI Cards Dos Drivers from the VOGONS driver archive.
SBPCI is configured as follows:
; PCI Hardware Configuration
PCIPort=d880
PCIIRQ=10
; Ports - MPU-401 and Sound Blaster Device
Port=330
SBPort=220
; IRQs - MIDI and Sound Blaster emulation
IRQ=5
SBIRQ=5
; DMA Channels for Sound Blaster emulation
DMA=1
DMA16=7
SBLOAD and SBINIT run just fine, card is detected.
I do get sound, so I've got that going for me, which is nice. I'm not sure the sound sounds as it should sound, but I've no experience with this specific card before.
It boils down to: sound effects are fine, music isn't. Music is low, soft toned. This is the case in multiple games, like Biomenace and Skunny Wildwest. In Prince of Persia there is music, but weird as stated before, and as soon as a sound effect should play, the whole system freezes and I have to hard reset. Basicly as soon as lvl1 starts, the sound of the gate closing is the mark of death.
So overal: yes it works, but it seems to me like it's not working as it should.
Any thoughts here?
3. Yamaha YMF724
I'm using the DS-XG dos setup. I've used both setupds v3.14 and v3.17
There are multiple topics on this card on VOGONS, I've read a lot of them. Like the Yamaha YMF7x4 Guide for instance: Yamaha YMF7x4 Guide
DS.INI is configured as follows:
LEGEN=1
SBIO=0
SBIRQ=0
SBDMA=1
MPUIO=0
MPUIRQ=0
INTAIRQ=10
IRQMODE=1
DMAMODE=3
I've used the setupds /s switch .
In the setupds utility, Native audio 16 bit works, although it's noisy. Background noise so to speak.
FM sound is crystal clear.
Sound Blaster is greyed out, as pointed out in the readme file.
My question here: is there a way to enable Sound Blaster compatibility with this one in Dos 6.22 ?
Final thought: Both the CT4810 and the Yamaha work somewhat on the FIC mainboard. On the p51430vx v2.0 they are not even detected. Any thoughts on that are welcome as well.
Cheers!
Reply 1 of 23, by Disruptor
Do you use a PC/PCI alias SBLINK cable? (for your 3rd card and perhaps 4th card)
Reply 2 of 23, by cyclone3d
The SBIO and SBIRQ are going to have to be set in DS.INI.
That being said, you may have to play around with the DMA and IRQ settings in BIOS to get it to work properly
May also have to switch the PCI slot that the card is in.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 23, by octopus
Disruptor wrote on 2022-02-05, 22:05:
Nope, I don't have one, and although I've come accross a few topics where it was mentioned, I'm not quite sure what it is and how to use it.
cyclone3d wrote on 2022-02-05, 23:14:
Not sure how I missed setting those in DS.INI , going to try that. --> update: set the configuration in DS.INI, alas to the same result.
BIOS settings are all on PCI/ISA PnP at the moment, not sure what to change here. The other option being Legacy ISA and the YMF is a PCI card.
Different PCI slots where used.
Somehow I missed this thread: Using Yamaha the YMF744 under DOS without legacy/ISA addressing where you talk about problems with PCI bridge on certain mainboards. I'll dive into this as well.
Thanks for thinking along!
Reply 4 of 23, by octopus
octopus wrote on 2022-02-06, 06:19:
Southbridge chipset is a VIA VT82C586, so that might be to old to get Soundblaster emulation working..
Reply 5 of 23, by Disruptor
It's a 5 wire cable with a 3x2 connector. One of the middle pins is free (key).
It may help with the Sound Blaster compatiblity if the DOS based Diagnose/Configuration program fails.
Reply 6 of 23, by Shreddoc
Could try the Unisound drivers with the ALS120 card.
Hate to even mention this - but I assume you had your speakers plugged into the correct jack when testing. (I have made this mistake before)
Your Diamond Edge 3D might be worth something. Looks like they're rare, asking price of $$$ on ebay. Not surprising, as nvidia's first historical 3d card.
Supporter of PicoGUS, PicoMEM, mt32-pi, WavetablePi, Throttle Blaster, Voltage Blaster, GBS-Control, GP2040-CE, RetroNAS.
Reply 7 of 23, by octopus
Shreddoc wrote on 2022-02-06, 07:41:
I didn't know about Unisound, thanks for the info! Tried it out, ALS120 is detected. Again, no sound from speakers.
And yes, I checked plugging it in the right port 😀
The Diamond Edge is indeed a bit of a special thing, I have the extension card with 2 ports for the Sega Saturn controlers. I'm keeping it around for when I run into one of those controlers.
The card itself works, but is inteded for W9X, in Dos it uses some kind of emulation that eats up a lot of ram. Haven't tried it in Dos 6.22 now that I think of it, only in Dos mode in W95 / W98.
Perhaps something for the afternoon...
Reply 8 of 23, by octopus
Disruptor wrote on 2022-02-06, 07:29:
Sounds useable, are there any requirements on the card or mainboard, such as connectors or slots?
Reply 9 of 23, by Disruptor
octopus wrote on 2022-02-06, 12:33:
Just connectors on both card and mainboard.
Reply 10 of 23, by AirIntake
Unisound seconded. Even if you don't end up using it to initialize your PNP sound cards it's a great troubleshooting tool to ensure your manufacturer PNP init tool is working properly or if you have a hardware error.
Casio BE-300 Advancement Society (be300.org) alumni
Reply 11 of 23, by Joakim
Maybe check the als100 jumpers.
Reply 12 of 23, by octopus
Disruptor wrote on 2022-02-06, 18:42:
You say 'just', but I have a feeling I might be unlucky 😁
What type of connectors would that be? Cause I'm afraid there aren't that mucht connectors on my main..
Further update: I realized my Win98 machine is an Aptica 2170, which is also running on a socket 7, but it's 4 years newer then my FIC mainboard.
So I figured, maybe the older FIC and Intel boards are unable to produce soundblaster compatibility (as far as I've understood the PCI CT4810 sort of emulates the ISA soundblaster over PCI), but perhaps the newer board from the Aptiva can work it out. Forgive me for not writing down the model and type of the mainboard, I didn't have a lot of time.
Anyway, this is what I tried and where it brought me:
BIOS:
Disabled PnP OS, disabled all PCI slots except one, disabled onboard sound chip. Not much options to configure IRQ's or Legacy ISA, and the BIOS is in French. Beautiful language, but I don't speak it so well. Google translate helped me, apart from the fact that most BIOSes have more or less the same interface chapters.
OS: I installed DOS 6.22.
Results:
ALS120, running Unisound: card not detected. Might be BIOS settings, but the options there are limited. There is 1 ISA slot on the board, so not much else to try with this one for now.
Creative CT4810: I didn't have the driver on CD, and didn't have the time to copy them to floppy (I have a limited amount of CD's and floppy's, I know, I should get more). So I didn't try this one yet.
Yamaha: card initialized fine, I fired up setupds and started to smile: Soundblaster was no longer greyed out! Then I got a DNA error, but hey, I like the challenge 😀 I couldn't save the configuration from setupds because of the DNA error, so I configured DS.INI manually. Just the basic P220, I5, D1 . Reboot, card initialized fine, setupds gave DNA error. Oh well, lets see if we can get sound anyway.
At that moment I realized MS-DOS messed up my partition, so I first had to copy MSCDEX and OAKCDROM, and then find a game that wasn't in a zip file. That turned out to be Prince of Persia 1.
Started the game and lo and behold: there was music from the speakers and it sounded like it should!
Then I got the same system lock as soon as lvl1 started.
That's where I'm at now. Conclusion so far: the FIC and Intel boards just can't cope with the Soundblaster emulation from the PCI cards, I'm still not sure why the ALS120 won't give a peep.
The board from the Aptiva understands at least the Yamaha PCI card, however there is still a DNA issue to figure out.
Fingers crossed for the CT4810.
I'll keep you posted when I find some spare fiddling time in the coming days.
Reply 13 of 23, by octopus
Joakim wrote on 2022-02-06, 20:25:
Thanks for the input! I checked if the jumpers might point to the lineout instead of speakers, but they don't.
Reply 14 of 23, by Shreddoc
Are you sure that no components have been removed from the cards by a previous owner (particularly the ALS100) ? We could inspect, if you are able to provide a photograph.
I once bought an Ensonic card, and later realised somebody had used it as a donor - had taken two of the smaller chips off the card - the result was that the card only played FM (music) and could no longer output digital sound.
edit: regarding your PCI sound card : do look into the PC/PCI - DSDMA - etc issue. Potentially relevant if using older PCI sound card in newer motherboard.
Reply 15 of 23, by Disruptor
octopus wrote on 2022-02-06, 20:41:
Results: Yamaha: card initialized fine, I fired up setupds and started to smile: Soundblaster was no longer greyed out! Then I g […]
Results:
Are you sure that you mean DNA error and not DMA error?
Well, I faced the same problem on a WaveForce soundcard.
The mentioned cable solved this issue but on some chipsets it may be possible without the PC/PCI alias SBLINK cable.
Re: Best PCI sound card to work on DOS natively
Reply 16 of 23, by octopus
Shreddoc wrote on 2022-02-06, 21:24:
I will look into that, thanks!
About the PC/PCI link: the Yamaha has one. I haven't found one on my mainboards yet.
Also, picture time.
ALS120:
The attachment ALS120_top.jpg is no longer available
CT4810:
The attachment CT4810_top.jpg is no longer available
The attachment CT4810_chip.jpg is no longer available
The attachment CT4810_chip2.jpg is no longer available
YMF724F-V:
The attachment YMF724F-V_top.jpg is no longer available
Reply 17 of 23, by octopus
On we go... Just installed the CT4810 in the Aptiva.
Also noted down the model of the mainboard, just to be complete: v75m 98141-1 , the Acer V75M mainboard.
I tried two different drivers:
Ensoniq Dos Drivers for Audio PCI - because the CT4810 is more or less a rebranded ESS card.
Card not detected, driver not intialized. Shame.
Just for flavour, a little side story: I had to copy the installation files by Floppy, and the EAPCI2M.ECW file is 2.207 kB. I know Norton Commander is able to split and merge files.
However, Norton Commander isn't to fond of Windows 10. So I'm using Total Commander 10 (64 bit). What do you know?
You can split a file in Total Commander 10 and merge it in Norton Commander 5. That's 26 years in between and it just works. Talk about backwards compatibility...
Okay, on we go. Second driver was the Sound Blaster PCI Cards Dos Drivers.
Card detected, initialized, looks promissing! Let's try it out..
I tried three different games: Prince of Persia 1, Dangerous Dave (original) and Bio Menace.
The results: Prince of Persia: screen went grey, system locked up.
Dave: speaker sound
Bio Menace: a sweet sweet symphony of sound blaster effects!
No all that's left is make sense of it all...
Reply 18 of 23, by octopus
Disruptor wrote on 2022-02-06, 22:07:
Are you sure that you mean DNA error and not DMA error? Well, I faced the same problem on a WaveForce soundcard. The mentioned c […]
setupds tells me the DNA is not available, but to be honost with you: I'm not sure on the difference between DNA and DMA (on sound that is).
Reply 19 of 23, by Shreddoc
octopus wrote on 2022-02-07, 19:22:
Dave: speaker sound
Correct. Dangerous Dave does not support sound cards.
octopus wrote on 2022-02-07, 19:26:
Please show us a photograph of that error message.
