First post, by phillipsrb
phillipsrb
Offline
HI,
When the DOSBOX window opens, it is always set slightly low so that the bottom line is partially obscured. It's easy to fix at that stage by dragging it but I was wondering if there might be a more elegant solution, e.g. something in the conf file?
Thanks
Robert Phillips
