First post, by emanuelect
I have a problem with the game lilo & stitch trouble in paradise. The game randomly crashes during the game's movies, and the loading images don't show up.
    17.71 KiB
Reply 1 of 4, by Dege
I can't reproduce movie crashes but you should try different compat modes (98, xp) because the game has heap overrun bug(s), probably that explains the random crashes.
The loading screen is also a game bug, if no pow2-textures are required on D3D side then the game code runs on an erroneous path (use the debug layer, it also reports an error), but I could patch that:
http://dege.fw.hu/Patches/bin/lilo_and_stitch … in_paradise.zip
Reply 2 of 4, by emanuelect
Now it doesn't crash anymore, it only happens when returning to the desktop. I also noticed that with this exe the game has fps drops, with the original exe it didn't happen. Can you modify this .exe? It's from the Italian version of the game, if I use the one you sent, the main menu starts in English.
    LiloIta.zip
    289.02 KiB
    58 downloads
