First post, by shimart
I bought an unidentified Hercules mono graphic card on eBay.
But it has a db25 printer port.
In my system, it causes an error.
I want to turn off the printer port, but I can't find any data related to jumper setting.
Can you give me advice after looking at the picture?
692.86 KiB
Reply 2 of 5, by weedeewee
Ydee, that's an odd link. Thanks for the reference though.
This seems more apropriate & direct. https://youtu.be/yXPpLLYMRqI?t=1229
edit : summarized video info
HM6311Q / MP 6311 (typical for google to not find that direct chip id in its search results. sigh)
this information wouldn't have been posted here without Ydee & Adrians digital basement info
Jumper Settings
JP10 ..... JP1
JP1, JP2 Printer port selection
JP1 JP2 LPT selected
on on disable
off on LPT1 (0x3BC)
on off LPT2 (0x378)
off off LPT3 (0x278)
JP3 COLOR/MONO Selection
ON COLOR
OFF MONO
JP4 Auto Switching selection
ON Disable (manual)
OFF enable
JP5 Character ROM selection
ON internal
OFF external
JP6 Auto screen blanking selection
ON disable
OFF enable
JP7 Color emulation Selection
ON disable
OFF enable
JP8 reserved
JP9 Font select
ON 7x7 font
OFF 5x7 font
JP10 ?
CGA mode set JP3 JP4 JP5 JP6 JP7 jP8 ON
Mono mode (CGA emulation) set JP5 JP6 JP8 ON , JP3 JP4 JP7 JP9 OFF
Do not ask Why !
Reply 3 of 5, by shimart
weedeewee wrote on 2022-02-10, 11:22:
Ydee, that's an odd link. Thanks for the reference though. […]
Jumper Settings
JP10 ..... JP1
on on disable
off on LPT1 (0x3BC)
on off LPT2 (0x378)
ON COLOR
OFF MONO
ON Disable (manual)
OFF enable
ON internal
OFF external
ON disable
OFF enable
ON disable
OFF enable
JP8 reserved
JP9 Font select
ON 7x7 font
OFF 5x7 font
JP10 ?
Thanks a LOT!!!
But, CGA MODE Don't Works... 😀
Reply 4 of 5, by Sergio Ayala
Hice un trabajo con una tarjeta de vídeo como la tuya,
ojala le sea útil estos PDF. Archivo en Ingles y Español
Saludos
    HM6311Q.pdf
    883.85 KiB
    42 downloads
    HM6311Q.pdf
    680.64 KiB
    38 downloads
    Español
Reply 5 of 5, by shimart
Sergio Ayala wrote on 2023-03-20, 00:11:
Hice un trabajo con una tarjeta de vídeo como la tuya, ojala te sea útil este PDF. This file is made in Spanish. ¿ Do you want i […]
¿ Do you want it in English ?
Saludos
Thanks!!! Perfect Manual!!
