First post, by Grzyb
I've just spotted this box:
85.48 KiB
...and one thing made me chucke - the frequency "counter" marked as LANDMARK MHz
The story behind Landmark "frequency" is fairly well known - it benchmarked CPUs relative to the original IBM AT, which used wait states, therefore zero-wait-states 286 clones exhibited higher values than their actual clock freqency, eg. 12 MHz was measured as 16.
But this is the first time I can see that fake frequency openly adverised on the front panel...
everybody knows about Statute Mile vs. Nautical Mile, Imperial Gallon vs. US Gallon, and so on... but did you know about SI Hertz vs. Landmark Hertz? 🤣
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 1 of 3, by Doornkaat
Is it possible that an LED behind the "LANDMARK" text would only light up in deturbo mode?
If deturbo didn't (only) decrease CPU clockspeed but (also) introduce waitstates or other stuff it would make sense for the display not to show the CPU clockspeed but rather indicate CPU performance.
AFAIK this particular system used an actual 16MHz processor.
Reply 2 of 3, by Grzyb
Doornkaat wrote on 2022-02-16, 10:16:
No LED there...
In this case, I would expect the "LANDMARK MHz" to be at least 20...
unfortunately, that particular machine got upgraded to 486, but if I ever find such a thing in original configuration, I'm sure to check it.
Reply 3 of 3, by Doornkaat
Grzyb wrote on 2022-02-16, 10:54:
No LED there... […]
No LED there...
Ok, then I was probably on to nothing there! I had a look at pics online and there are variations of this case (and computer model) without the LANDMARK text. They all have an actual 16MHz CPU as far as I can tell.
Did they actually cheap out at some point in this model's production? Or did they try and make owners of 286 PCs feel better about their systems' performance later on with that Landmark thing? I'd really like to see the original config now!😃
Nice oddity either way! 👍
