Voodoo II SLI Noise
First post, by murrayman
Hi, I’m new to Voodoo II SLI, can you tell by the title? 🤣
Okay, so I’ve had my one Diamond Monster 3D II for a while now, and between it and my DM3D 1 card, I’ve become intimately familiar with the signal noise as compared to Voodoo 3 on up, as well as up to speed on others notes about it over the years. It seems my two cards are fairly decent - when I let my LCD monitor auto align at 640x480 on both, and 800x600 on the II, I can only see a faint bit of scrolling when rendering, and none at all when displaying from a 2D / other 3D card using the newer insulated patch cable I have.
Here’s my question: To what extent can adding a second Voodoo II for SLI introduce further noise? I bought a second DM3D II card that has different brand memory chips from my first, and when paired with the other using the FastVoodoo2 4.6 drivers and a black Abit-branded SLI bridge cable, SLI works just as it should, but now there’s MUCH more visible scrolling on the display when rendering, along with some general signal noise - dirty enough to be distracting even when there’s a lot happening on screen. The issue is not present when outputting from the 2D card.
Currently testing in a pieced-together rig from parts in my sig. Setup is as follows:
- Corsair CX650M
- Asus P3B-F v1.04
- Pentium III 1.0Ghz @ 133 FSB
- 512MB PC133 RAM
- Creative GeForce 256 DDR 32MB
- SB0160 sound card
Monitor is a Dell 2007fp using a thickly insulated, filtered VGA cord that’s served me well with all other setups.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
Reply 1 of 1, by The Serpent Rider
Voodoo 2 SLI use analog to sync rendering between frame buffers, on top of already noisy DAC for single card. So you can't really get rid of it completely, but you can reduce it with forced vertical sync.
