First post, by =zum=
I was Playing Monkey Island 1 and i hear the sound effect of a door is incorrect for the real one... in version 0.64 (?) version of dosbox this bug will be fixed?
Thanks.
Reply 2 of 19, by DosFreak
It would also be nice if the poster was more exact. I'll check out ScummVM vs DosBox for MI1 tonight....
Make your games work offline
Reply 4 of 19, by HunterZ
You should record the sound from your real OPL2, from DOSBox, and from SCUMMVM and post it here (or the DOSBox bug tracker) and to the SCUMMVM bug tracker. Otherwise, noone will bother to look into it for you. I'm speaking from personal experience here...
Reply 6 of 19, by =zum=
Ok Guys...i've recorded the sound...it's a door in monkey 1 floppy version..opening e closing. (same sound in indy3)
Sorry for the bad recording of OPL2 Genuine and Scummvm Emulation but i have a stupid microphone 😜
I also post it on bug tracking of dosbox and scummvm 😉
Here we Begin with Genuine OPL2
    Genuine OPL2.mp3
    58.78 KiB
    563 downloads
    Real Sound Effect Recorded via Microphone
Reply 7 of 19, by =zum=
    DosBox OPL2 Emulation.mp3
    91.84 KiB
    544 downloads
    The DosBox Emulation of the effect..recorded via Dosbox (CTRL+F6)
Reply 8 of 19, by =zum=
    Scummvm OPL2 Emulation.mp3
    64.9 KiB
    539 downloads
    And Finally the Scummvm Emulation...this damn sound has try one time, when i forget the high volume, to make me deaf! :D
Reply 10 of 19, by =zum=
Yes! That's beacuse i created this topic...wait...i've discovered another leak in AdLib Emulation.....Exactly, this time i've listen the difference between Real OPL2 and Dosbox and Scummvm (same sound in this way) on the Scummbar Theme of MI1....
This time i've hear some metallic sound that not appears in the original track!
Listen:
    ScummBar-Real OPL2.mp3
    574.29 KiB
    524 downloads
    Here's the real track recorded via microphone
Reply 11 of 19, by =zum=
    ScummBar-DosBox and Scummvm Emulation.mp3
    519.18 KiB
    525 downloads
    And this is the emulation with the metallic sound... recorded via CTRL + F6 in DosBox
Reply 13 of 19, by NewRisingSun
It's not like anyone will bother even if he does. I'm speaking from personal experience here... (*scnr*)
Reply 15 of 19, by NewRisingSun
Why not? You'll use it anyway to ask questions about Tandy sound or lecture people about being deferential towards you.
Actually, I was referring to Incorrect FM in Commander Keen 6.
Reply 16 of 19, by wd
Rank DOSBox Author
DOSBox Author
> Actually, I was referring to ...
If there's no reply then this *might* mean that nobody has found
a solution yet, not that something is ignored or whatever.
Don't know what you want with the first part of your post.
Reply 18 of 19, by =zum=
I Just recorded the sound of the door by real adlib using a output-input connecter but i founded some problems while hosting it, as soon i return from rome i can retry hosting it on my own space, just wait to 18th
