SB PCI128
First post, by Peter.Mengel
Hi, a question if i use this card for dos games through windows 98 i have to choice it unter Multimedia MIDI Right?
But ill have 2 choices.
1. SB SB PCI128 MIDI Synth
2. SB PCI128 MIDI Out
What should i choice to get the best quality?
Or does this changes anything?
Thank you.
Reply 1 of 11, by Doornkaat
If I'm not mistaken option 1. is the card's own MIDI synth (probably a software solution) while 2. is selected if you have an external MIDI module connected to the card through the joystick port.
Reply 2 of 11, by leileilol
You'd better love that Ensoniq Concert Wavetable set because that's all you're getting for any synthesized music with that card 😀 The DOS TSR will try its best to translate all OPL2 to it and is one of the unique guilty pleasures (besides some older Live! cards)
long live PCem
Reply 3 of 11, by Peter.Mengel
leileilol wrote on 2022-02-20, 05:56:
Sarcasm? Cause i did like the sound it sounds very SoundBlaster like in the "old" days.
Reply 4 of 11, by Peter.Mengel
Doornkaat wrote on 2022-02-20, 05:41:
Tried them both, it doesnt change anything but ill changed it to synth. Thanks for the help.
Reply 5 of 11, by Doornkaat
Peter.Mengel wrote on 2022-02-20, 06:25:
Maybe the card defaults to its own synth/wavetable if no MIDI device is physically connected? Anyway, it's a good thing it works and one shouldn't argue with a good thing.😄👍
Reply 6 of 11, by leileilol
Peter.Mengel wrote on 2022-02-20, 06:24:
That's the thing, the SBPCI 128 isn't like a Creative Sound Blaster. It's an Ensoniq card at the core with some TSR support for some Sound Blaster compatibility (varying between driver versions) and the FM emulation never really improved (and sounds nowhere close to the OPL2/3 of the old cards). It can't use soundfonts or the AWE functionality either.
Probably the biggest saving grace is the A3D and EAX 1.0 support which some earlier (as in 97-99 early windows 3d sound games) games can work with, and having some care in DOS sound support at all (most early PCI sound cards and later onboard audio i.e. SoundMAX - didn't). It's still a rock and a hard place though.
long live PCem
Reply 7 of 11, by Peter.Mengel
leileilol wrote on 2022-02-20, 08:58:
Would you say the Audigy 2 is better for Sound?
Reply 8 of 11, by jmarsh
No great loss there, can't think of any game that has better support for SB AWE rather than general midi (aka MPU-401 on port 330, which the SB PCI handles using wavetable playback with the .ecw banks).
Reply 9 of 11, by pc-sound-legacy
Ensonic/Soundblaster PCI has the worst FM emulation I've ever heard.
https://youtu.be/1dOSDhPP3fM
The software wavetable is great btw. so if you like to run newer DOS games with General Midi support, it's fine. Sound (FX) is fine, too.
Soundblaster Live! and Audigy also have FM emulation but it's far better and improved.
Audigy 2 I'm not sure if legacy drivers are available (I think so). If so, yes it is definitely the card of choice. Anyway, best PCI card for DOS is a Card with the ESS Solo-1 (ES1938) chip and a wavetable header, at least in my own opinion.
Reply 10 of 11, by leileilol
jmarsh wrote on 2022-02-21, 13:09:
It's not a card suitable for Magic Carpet 2, Hi-Octane, Eradicator, and FF7 at least 😜
long live PCem
Reply 11 of 11, by Peter.Mengel
Got a Aztech 2320 now it sounds rly good. Had a ISA Board for a P3 here and the Card was rly cheap. Thanks for the help 😀
