First post, by ocdmonkey
I've been trying to get this to work for a while now, but I just can't figure out what I'm doing wrong. No matter what I do, when I launch Hero's Quest I just get a black screen with a mouse cursor, where it was working fine before I reconfigured it to expect an MT-32 using the install program. SoftMPU seems to say it's working perfectly fine based on its output on startup. I'm using this with a Sound Blaster 16 (I believe a CT2290).
Thanks in advance for any help!
@ECHO OFF:: DOS Stuff:PATH C:\WINDOWS;C:\DOSSET LMOUSE=C:\DRIVERS\MOUSESET TEMP=C:\TEMPSET TMP=C:\TEMPSET DIRCMD=/P /Aloadhigh C:\DOS\DOSKEY /INSERTloadhigh MSCDEX /D:MSCD001 /v:: Mouse Drivers:C:\DRIVERS\MOUSE\CLOAKING.EXEC:\DRIVERS\MOUSE\MOUSE.EXErem loadhigh c:\dos\mouse.com:: Soundblaster:SET SOUND=C:\DRIVERS\SB16SET BLASTER=A220 I5 D1 H5 P330 T6SET MIDI=SYNTH:1 MAP:EC:\DRIVERS\SB16\DIAGNOSE /SC:\DRIVERS\SB16\SB16SET /P /Qloadhigh c:\drivers\softmpu /SB:220 /IRQ:5 /MPU:330PROMPT $p$g
; Main DOS configDOS=HIGH,UMBFILES=40; MemoryDEVICE=C:\DOS\HIMEM.SYS /v /TESTMEM:OFFDEVICE=C:\DOS\EMM386.EXE; SoundblasterDEVICEHIGH=C:\DRIVERS\SB16\DRV\CTSB16.SYS /UNIT=0 /BLASTER=A:220 I:5 D:1 H:5DEVICEHIGH=C:\DRIVERS\SB16\DRV\CTMMSYS.SYS; Misc DriversDEVICEHIGH /L:1 = C:\DOS\ANSI.SYSDEVICEHIGH /L:1 = C:\DOS\DISPLAY.SYS CON=(EGA,,2)DEVICEHIGH = C:\DOS\VIDE-CDD.SYS /D:MSCD001 /P:1F0,14 /P:170,15 /P:1E8,12 /P:168,10STACKS=9,256
