First post, by Intel486dx33
Hey Guys,
I have another NOS 486 motherboard with a Dead Dallas.
It does not have connection pins for an external battery but the markings are there for a jumper and traces for an external
Battery connection. PLEASE SEE PHOTOS.
I was wondering if I could add an external battery by soldering onto the motherboard and wires for an external battery ?
And soldering on a wire for the jumper ?
Reply 1 of 12, by stamasd
I am sure that whatever J10 does, it is not a header for external battery. The Dallas DS12877 does not have pin connections for an external battery.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 2 of 12, by TrashPanda
https://ardent-tool.com/misc/Dallas_Rework.html
have a look here, this site might give you pointers on how to dreme .. uhh deal with them pesky Dallas RTCs...
Just uhh forget I mentioned Dremel ok.
Reply 6 of 12, by snufkin
Intel486dx33 wrote on 2022-02-22, 21:06:
Hey Guys, I have another NOS 486 motherboard with a Dead Dallas. It does not have connection pins for an external battery but th […]
Hey Guys,
It's possible that those are for a version of the RTC with a clear function (12887A maybe?). I guess that R2 pulls pin 1 of J10 high and that fitting a jumper will connect pin 1 to Ground, which if pin 1 goes to pin 21 of the RTC would clear the CMOS. I don't think any of the Dallas chips have any pins for an external battery, hence the various mods involving cutting in to the casing to get at the internal battery points.
You can check if I've guessed right by measuring the resistance from J10 pin 1 to the Dallas pin 21. If they're connected then it's CMOS clear. If they're not connected then it might be interesting to find out what J10 does connect to.
Reply 7 of 12, by fool
There are some averagely smarter board designers. This option is rare as it needs footprint to solder battery holder in.
    245.35 KiB
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 8 of 12, by mpe
snufkin wrote on 2022-02-23, 10:06:
DS1385/DS1387 does. But it is far less common that DS12887 or like models.
Blog|NexGen 586|S4
Reply 9 of 12, by Intel486dx33
The problem I have with cutting into the Dallas is that it is right next to the Bios chip so it is impossible to cut into the side of it
Unless I has some sort of small dremil bit which I don’t
I think I will have to desolder the Dallas and use one of those coin battery adapter replacements.
Once I find the right adapter for my Dallas 1287
Reply 10 of 12, by debs3759
It might be easier to just replace it with https://www.tindie.com/products/glitchwrks/gw … acement-module/
Reply 11 of 12, by Intel486dx33
debs3759 wrote on 2022-02-23, 12:24:
Yes, is that the right one for the DS1287 replacement ?
Reply 12 of 12, by debs3759
Yes
