XT IDE DIY card
First post, by tony359
Hi there,
I'd like to make my own XT-IDE card, I see a few projects online, does someone have any recommendation to which one to go for?
I like this one http://dangerousprototypes.com/docs/XT_IDE_disk_controller but I don't see much activity around it. Otherwise I see this one: https://www.glitchwrks.com/xt-ide
Any thoughts?
Thanks
Tony
My Youtube channel: https://www.youtube.com/@tony359
Reply 1 of 4, by bakemono
The first one is a smaller board with fewer parts, but it requires SMD soldering and programming a CPLD. Looks like the glitchwrks one is all throughhole. It depends on your capabilities and experience which one you might want to tackle.
If it was me I'd use a throughhole CPLD for easiest board assembly.
Wreckage reimagined on itch: https://90soft90.itch.io/wreckage-dash
Reply 2 of 4, by Sphere478
it's of course your prerogative to make one if you wish, And I will cheer you on. But I am curious as to your motivation though as assembled ones are not that expensive next to the risk of making your own and the additional effort.
I have a blue lava one which works well. no ide port though. and the risk of backwards insertion is always having me worried.
Sphere's PCB projects.
Reply 3 of 4, by tony359
Sphere,
Half of the fun is ordering the PCB, waiting 4 weeks, ordering the parts, burning them while soldering, fitting some the wrong way etc! 😁 Otherwise it's boring! 😁
SMD appeals me - gives me some opportunity to do SMD soldering. I have no problem with that. It's just that the project seems a bit "dead in the water"?
Reply 4 of 4, by Jo22
I see, makes sense. I love challenges, too. It's just the opposite that appeals me. 😆
I find it fascinating to make as much as possible by my self.
That's why I love through-hole, discreet circuits, etc.
But SMD per se isn't bad, I think. There are reasons for an old school fan to give it a go, too.
Balloon missions (high-altitude ballooning), single-sided PCB designs, R/C models etc..
Also, SMD parts don't have to be small per se. Big SMD components also existed.
In this case, I'm a bit surprised that both designs use a flash/eeprom still.
Why does the CPLD version not something like a microcontroller/SRAM/serial EPROM etc?
That chip surely could assist interfacing modern RAM to the bus..
Edit: The link to the benchmark is dead ("buffers=99").
Here's an alternative link to it.
https://www.lo-tech.co.uk/wiki/DOS_Disk_Tester
