First post, by Frippu
Hey guys I'm havin a problem with my Nokia 1610 my dad have this Nokia and we wanted to try and get it back to life but we don't have the original charger so I tried to find the charger in the internet and I actually found some but they were too expensive so I found this charger that you can set voltage on it with the same connector that the Nokia have but you can set the voltage to 9v 1000mA or 12v 1000mA ut the original was 10v at 750mA so the question is will the charger charge it with no problem at 9v or 12v?
