First post, by Aui
- Member
Hi everyone - I got my hands on an old DELL 466/ME and I like it a lot.
Restoration is almost finished and there is just one last, but yet difficult remaining problem. The PC has a Canon MD 5511 Dual Floppy drive. The good news is - that the large 5.25 inch drive is working ok. However the smaller 3.5 inch drive is not - and I am running out of ideas what could be the problem. Here is a quick list of things tried so far:
- the drive looks clean and there is no obvious damage etc.
- I cleaned the drive and added new Li-grease to the gear driving the head.
- cleaned the heads with IPA
- the drive is spinning
- the drive is recognized in BIOS and DOS
- I can access the drive and it recognizes it and starts reading (tested with a known good disk) - but stops after a few seconds ("cant read disk...")
- If I try to format a new disk it also starts formating but aborts with a message "invalid track / track 0 bad / disk unusable"
- Any ideas how to save the PC in its current style would be greatly appreciated as I feel it would loose a lot of charm if the dual drive is replaced.
Thanks already in advance for any ideas and suggestions.
