GoTek/FlashFloppy woes
First post, by hardrivethrutown
I'm aware that I'm not the only person who's been having these issues, those being getting *ERROR* 34 when trying to set up a GoTek floppy emulator running FlashFloppy firmware.
I recently bought one of the higher-end models, with the OLED display and rotary encoder (those little units do look nice), wanting to attempt to update the bios on an old NT4 workstation machine from around ~1997, Dual Slot2 Intel MS440GX motherboard. The latest BIOS revision should support up-to Pentium 3 Xeons @550MHz 2MB cache, and GeForce FX cards (of which I have a pair of 550MHz P3X's w/ 2MB cache and an old FX5200 I want to put in there, yeah I know it's not period accurate but I want something cheap with DVI and VGA out).
I went through the standard procedure from the FlashFloppy Github, making a FF.CFG file:
interface = ibmpc
host = unspecified
pin02 = auto
pin34 = auto
write-protect = no
display-type = oled-128x64-rotate*
oled-font = 8x16
display-off-secs = 255
step-volume = 20
*initially I didn't have the [-rotate] string in the config file so it made the display upside-down, but I fixed that pretty quickly.
Only thing I haven't been able to get around is *ERROR* 34, I've changed the config file countless times and put some blank 1440k floppy images on the drive (FAT32, 8GB USB2 flash drive), putting them in different folders or in the root folder, but alas, I'm still stuck at this point.
file.php?mode=view&id=131967
Tried talking to some friends that are more well-versed at this kind of stuff than I am, and they're equally stumped.
I want to get somewhere with this thread so that in future people who have the same issues can get them fixed.
Systems:
- R5 2600, GTX 1070, 16GB
- i7 950, GTX 480, 12GB
- C2Q Q6600, HD3870, 4GB
- Athlon 64 3500+, 6800GT, 2GB
- P4 3.2, FX55008X, 4GB
- P2 400, TNT2, 512MB
- P2 Xeon 400, Elsa PCI Video, 384MB
Reply 1 of 2, by hardrivethrutown
Turns out I'm just a bit of an idiot, I got the impression from the documentation that everything had to be under a /FF subfolder (config files, images etc), but I got everything to work after putting it into just the root of the drive.
ROOT:
/d_images
FF.CFG
IMAGE_A.CFG
then in the /d_images folder I put all the relevant disk images... Still need to find that BIOS update though.
Systems:
Reply 2 of 2, by Jo22
Nah, don't worry, to err is human. We all had been there at some point.
Just look at me, I managed to kill an USB pen drive with a Gotek. With the stock firmware! 🤦‍♂️
Glad you got it working, after all! 😎
