First post, by JustJulião
Hi,
In my company's old stock I found a Chips&Technologies F65550 B.
http://www.vgamuseum.info/index.php/component … nologies-f65550
My card has different outputs though, see attached pictures. I couldn't find one with the same outputs to get some information.
I don't manage to use it on my VGA screens even though it looks clearly like a VGA ouput. I tried old and newer flat screens, the oldest doesn't even try, the newer says it's "not supported".
How can I use it on a screen ?
I manage to obtain the output with a capture device on OBS (that's how I made a screen capture of the splash screen) so I know the card is working properly.
    81.92 KiB
    389.42 KiB
    1.07 MiB
Reply 1 of 7, by cyclone3d
My guess is that it was for some sort of lvds monitor in a luggable.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 7, by Cuttoon
Did you link to the correct page on VGA legacy?
I got this:
All those cards appear to have some kind of Video in/out capability.
That golden RCA connector and probably some proprietary breakout cable for the middle connector.
Should be interesting what happens if you attach a TV to that RCA connector - many TVs should still offer that input, maybe via a SCART adapter.
Video I/O was rather early or exotic, that being from 1996. Maybe they screwed that up somehow.
That small AD chip on yours in the upper left corner seems too primitive to provide a "video out" all on its own.
OK, that's what it does:
https://www.mouser.de/datasheet/2/609/AD724-1501848.pdf
But part of the work will be done by the main chip, other than VGA.
Maybe that's prompting it to provide some exotic VGA modes or messes with DDC communication.
At 1996, it's probably still older than any of you TFTs?
I don't think it's a malfunktion, but if so, there might be one that fails to get the monitor started, not providing a certain signal.
That would fit the fact that the capture device still gets a picture.
Someone here will know much more about such things.
What I would try:
Install that thing in a more modern windows system along the main card, use it as a secondary VGA and see if you'll get a picture at certain settings. If you manage to find a driver...
I like jumpers.
Reply 3 of 7, by darry
Check the timings the video capture card was seeing when connected and share them .
My guess is that the VGA card is preconfigured to work with some old RGB fixed sync CRT monitors from the likes of Apollo, HP, Sun, etc .
EDIT: Or maybe it is something from the medical field
Reply 5 of 7, by JustJulião
Cuttoon wrote on 2022-03-06, 18:47:
Did you link to the correct page on VGA legacy? I got this: http://www.vgamuseum.info/index.php/component … nologies-f65550 […]
I got this:
What I would try:
Thank you, I edited the link.
Finding a driver might be hard while it's integrated in W98. And it's a 96 card. Yes, my TFT's are from 2003 at best. I don't have CRTs. I'll first try to see if my capture device (USB3HDCAP) can give me some information on the input, like some people here suggested, but i tried already and didn't find in OBS. I'll try with the provided software (Streamcatcher).
Reply 6 of 7, by Cuttoon
JustJulião wrote on 2022-03-06, 22:57:
If you look for the chip, you'll find some drivers for XP at least:
https://de.driverscollection.com/?H=65550%20P … %20Technologies
Win XP might be something of a sweet spot for auto detection and drivers of 90s stuff?
Could also be that some recent Linux "fire and forget for dummies" distros like Ubuntu are pretty fit, especially for arcane pieces.
If so, a live CD and internet connection would already suffice.
But, I don't know. Someone here will have figured all that out, at some length.
I like jumpers.
Reply 7 of 7, by jmarsh
Pretty sure the same chipsets were used in Toshiba laptops back in the day. An external monitor connected to the VGA port had to be activated either with a special keypress or in the C&T windows software.
