First post, by Kahenraz
Kahenraz
Online
- l33t
The default behavior is overtype, which causes any character under the cursor to be replaced by the key that is typed. This behavior can be toggled to insertion mode with the "insert" key. The problem is that this is temporary and resets back to overtype after hitting return.
I don't like overtype and much prefer insertion mode. Is there a way to change the default behavior to insertion mode?
