First post, by Repo Man11
So you try a different power supply, take it out of the case etc., only to finally discover this (note the orientation of the power switch):
Reply 1 of 5, by Repo Man11
To be fair to me, what's on the motherboard makes it look as though the power and reset switches should go on pins 16 & 17 and 18 & 19 rather than 17 & 7 and 19 & 9.
Reply 2 of 5, by chrismeyer6
Your not alone I've had similar happen to me in the past.
Reply 3 of 5, by BitWrangler
When things are going pear shaped, just think to yourself, "This sounds like a job for Artie... who? .... Artie Effem." 😁
Reply 4 of 5, by TrashPanda
BitWrangler wrote on 2022-03-11, 03:50:
Sounds like a job for a screwdriver to short some pins, or to just press the power on button on the motherboard ...Yes some old boards have this.
Then a little later say while you are asleep your brain wakes you up and points out that you forgot to RTFM and you have it connected to the board the wrong way.
Reply 5 of 5, by Errius
Viagra does wonders I hear
Is this too much voodoo?
