Ess 1868F audio problem.
First post, by kenan83
Hello. I'm collecting 486 systems. I added an Ess 1868 F sound card to the system. I introduced it to DOS 6.22 and tried a game for sound. The sound of the game comes from the speaker inside the case, not the sound card. I know I installed the sound card, but is there a way to find out? Thank you.
Reply 1 of 3, by TOMMY_THE_DOG
Which driver did you install? What game are you playing? Did you run the setup/config application for your game and configure your soundcard?
Reply 2 of 3, by Pierre32
You should have something like this in your autoexec...
SET BLASTER=A220 I7 D1
C:\AUDIODRV\ESSCFG.EXE /A:220 /I:7 /D:1 /B:330 /J:E
C:\AUDIODRV\ESSVOL.EXE /V:8 /L:8 /W:8 /M:0 /C:8 /S:8 /A:0
Reply 3 of 3, by kenan83
Problem is solved. Thanks.
