First post, by idan182
Hi all
I have a Macronix Voodoo Rush card that won't play or load some games.
Like "The Sims 1", I can see the logo but it goes back to windows where the second subtitles move (logo of the game)
I also play Heroes of might and magic 3 and it runs ok.
I'm not sure if that's a driver problem related.
I switched to my Diamond Stealth 2000 2MB, Sims runs but very laggy and slow.
On the other hand, Heroes 3 won't run at all. I can see the yellow cursor at the begining, but it goes back to Windows.
My system is
Pentium 233MMX
256MB RAM
Is Heroes 3 a requires 3d card?
Why the sims 1 can't run at all with the voodoo rush?
Would you recommend me a better card? like Diamond+Voodoo 1 or 2?
I see the minimum requirements of sims is just 2mb video card, is the diamond just bad for that?
Reply 1 of 2, by leileilol
The Sims's software rendered and will run bad regardless of what video card you use with that processor. Hope you aren't running any expansions on it....
Reply 2 of 2, by idan182
Bump
Any more recommendation for a graphic card?
Most of the games I play are on DOS.
And the only few I play on WIN98, is Roller Coaster tycoon 1/2 which runs great on the 2MB S3.
Heroes 3, Midtown Madness maybe
I want to keep the S3 for the dos games, should I get Voodoo 1/2 with a pass thru cable?
Or a different 2d/3d video card something like the Rush?
