First post, by Darelius
Hello there, i have a probloem with my dosbox sound.
I was born 1974 and my first Computers worked with MS-DOS 2.11 so im not a "totally" newbie with computers π
My problem is following:
I have MANY old dos games, they were running with windows 7 and dosbox most times without a problem
Now on windows 10 i have a weird problem.
Installing Steam/GOG DOS-games - they work with sound without problems.
Installing DOSBox 74-3 and the terror begin π
The "fullscreen" problem i solved by changing some options, but i can not bring the sound device to work properly.
Even if i "copy" the config file from the games of gog/steam with dos, it wont work. (Master og Magic GOG or XCOM from steam)
So, following "sound Options" are in the config file and worked for years:
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
But since i have windows 10, it seems to be "broken" in some way.
So my question: Do i have to install any other "additional" probram/driver?
And why the F... is it working with Dosbox from steam/gog?
Or did i just miss a small thuing, because im "blind" ? π
...DX
P.S.: I wanted to play some dos games and none worked with sound. Named: Master of Orion 1, Lands of Lore 1, Eye of the Beholder 1 etc
