First post, by Nic-93
So, i werent sure if this was a fitting subject to post it under, but a while back i found this on github and it seems to be leqit, got somebody i talked in private with to compile the software, but it really need's some work to sound good.
so mostly wanted to bring attention to it, if there was some people here who were interested on giving it a shot to help improving its quality and sound. I'm impressed it works at all.
https://github.com/skjelten/emusc
Reply 3 of 31, by AppleSauce
Karmeck wrote on 2024-02-05, 21:47:
So how much of the SC55s hardware is still an unknown quantity? Is this the last chip they had to figure out?
Either way hopefully it helps skjelten , he did some updates recently to emusc so its slowly getting there.
Reply 5 of 31, by mattw
I presume the dump is not publicly available, right?
AppleSauce wrote on 2024-02-05, 22:57:
it's the last ROM that was not dumped. however, there are significant open questions, discussed many times in different threads here, last time I believe was here:
Re: sc55mkII vs. sc55st ROM Analysis and Demo Song?!
BTW, if someone needs easy way to decrypt the SC55 WaveROMs:
Re: About Roland Virtual Sound Canvas 3
Reply 9 of 31, by AppleSauce
With a recent update all the major components of emusc have been implemented and now it is a matter of fine tuning and polishing to get it sounding right.
168.17 KiB
Reply 10 of 31, by mattw
AppleSauce wrote on 2024-03-30, 00:24:
I am guessing now it's much easier to spot when the sound is not right after the following is out of the way:
still, even when finished 'emusc' will not work for all games, because according to this list:
Re: Apparently not all GS-only sc-55s are the same, some are GM
none of those are working with SC-55 and they need SCC-1 (and/or Computer Module boxes based around it, like CM-300/500), because of specific "Capital Tone Fallback" behavior:
and 'emusc' is kind of hard-coded around particular SC-55 ROM version...
Reply 11 of 31, by AppleSauce
mattw wrote on 2024-03-30, 09:31:
I am guessing now it's much easier to spot when the sound is not right after the following is out of the way: […]
I guess since emusc supports multiple different roms , that might offer a way around the problem?
54.29 KiB
Reply 12 of 31, by mattw
AppleSauce wrote on 2024-03-30, 10:07:
it doesn't do much with those ROMs other than to list them. essentially those ROMs use is limited to generate table like this one:
https://docs.google.com/spreadsheets/d/13LyKT … dit?usp=sharing
more details:
https://github.com/Kitrinx/SC55_Soundfont?tab=readme-ov-file
which is more or less hard-coding to a particular ROM version. I doubt 'emusc' moved away from that approach, even I haven't looked at their source code lately.
Reply 14 of 31, by kode54
This synthesizer appears to be affected by this bug:
The Roland Sound Canvas SC-55mkII may be out of tune when powered on without a battery
Edit: Here's the reset procedure you need to do every time you turn it on with this emulator:
1) Press Q to turn it off.
2) Press and hold Y and U, then press Q to turn it back on.
3) Press W to answer affirmative to the reset prompt.
Edit 2: I'll report this on the issue tracker as well, but there's also an issue with missing tones in CANYON.MID. The piano has an odd bank number.
Reply 15 of 31, by Spikey
Karmeck wrote on 2024-04-02, 17:40:
Emulator is now released. Requires rom files. […]
https://github.com/nukeykt/Nuked-SC55
Comparison with real hardware.
https://twitter.com/CrakerMc/status/1775200087700078690
Either that demo is flawed or the emulation is still a long way off in terms of reverb/chorus.
Reply 16 of 31, by KainXVIII
Is it supposed to be this heavy on cpu (around 20% used) or its will be optimized further?
Reply 17 of 31, by Karmeck
KainXVIII wrote on 2024-04-03, 11:29:
That issue is discussed, here:
https://github.com/nukeykt/Nuked-SC55/issues/8
Reply 18 of 31, by Karmeck
This has now been addressed in the latest release.
Reply 19 of 31, by Karmeck
Spikey wrote on 2024-04-03, 05:04:
This is yet to be implemented.
As stated in the comments here.
https://twitter.com/nukeykt/status/1768257753 … OwNSFpv70g&s=19
I have attached a screenshot of the comment, if those that which to view it, might not want to have/crate a Twitter account.
