486 motherboard cache
First post, by andy120
I'm a bit lost here. My pine pt-432b is saying bad cache or fails to boot. if cache is disabled it boots fine. there are 5 UM61256-15's plus 4 257's. None of the 4 jumper options for size work, being 125kb 32k8 x4 + 8k8 x1 , 256KB 64k8 x4 + 32k8 x1, 256KB 32k8 x8 + 32k8 x1 , 512KB 128K x8 + 32k8 x1 options. which should i use? i also have enough UM61256-15's to fill all the sockets and have some UM61512-15's, what is the best option or possible source of the issue?
the spec is 128k-1024k CACHE in 4-28pin 4-32pin sockets + 1 TAG RAM socket
Powered by one Harris 286-12
Reply 1 of 32, by Cuttoon
You should provide more information up front.
I assume it's this board here:
https://www.ultimateretro.net/en/motherboards/7963#downloads
Screenshot from the manual - maybe someone can figure it out, too early in the day for me:
I like jumpers.
Reply 2 of 32, by Doornkaat
Can you post pictures of your board? That's always helpful when trying to figure out issues on hardware that has jumpers and lots of socketed/changeable ICs.
Reply 3 of 32, by Cuttoon
Doornkaat wrote on 2022-03-23, 08:55:
There's a good generic one at the page i linked to but yes - picture of the actual patient couldn't hurt!
I like jumpers.
Reply 4 of 32, by Doornkaat
Cuttoon wrote on 2022-03-23, 09:08:
I'm asking for a picture so the configuration on the OP's board can be confirmed and to see wether there are any obvious defects. Visual inspection is the first step of hardware troubleshooting, isn't it?
Reply 5 of 32, by Cuttoon
Doornkaat wrote on 2022-03-23, 09:29:
indeed!
I like jumpers.
Reply 6 of 32, by waterbeesje
Long shots while the pics may be on the way.
Some boards require specific SRAM layouts and properties. Although they are electrically compatible they may be different on the inside and the board just refused one kind.
Could you try with only the 5 256 chips?
That working, may indicate some incompatibility and the system may dislike the combined 256/257 chips.
Or swap these chips one by one too see if one is broken.
Also try to insert some wait states, maybe that's the issue of things seem unstable. Some faster Socket 3 CPUs push the 15ns chips to the limits or slightly over.
There's also a slight chance order chips are just printed with the 15ns rating but can't really go past 20 it even 25 (really nasty but it happened)
Stuck at 10MHz...
Reply 7 of 32, by andy120
pic of existing cache
Reply 8 of 32, by CoffeeOne
andy120 wrote on 2022-03-23, 21:10:
Trying out all combinations of the jumpers is weird.
So you have 8 times 32Kx8 and one time 32kx8 for tag ram.
It seems that the winbond chips were added to board later. Are they fake chips?
Reply 9 of 32, by andy120
they all have traces. if i use the 512's i have and know are good, i should install 4 right?
Reply 10 of 32, by Disruptor
Try the 128K setting first with 4 modules in the 32 pin sockets plus tag.
What happens?
Reply 11 of 32, by andy120
That worked, but only write through, totally fails write on back. Im running a amd 5x86-133 currently. Is write back essential?
Reply 12 of 32, by Disruptor
Okay. Please run SpeedSys 4.78, generate a .PCX picture afterwards inside the program, convert it to .PNG and post it here please.
I'd like to see the cache chart right bottom of the screen/picture.
I suggest to deal with write back later.
Does it still work when you swap the 4 modules by the unused modules?
Reply 13 of 32, by andy120
it appears there are too many stuffed 256's than i have replacements, so it has 4 new 512's in.
Reply 14 of 32, by Disruptor
Well, I don't see an active L2 cache at all in that chart.
Reply 15 of 32, by andy120
shizer. is that why write back doesnt work.
edit
just seen the boot screen says 256k cache with 512's in and jumpers for 512. i assume that means fake cache. also didnt have 32-bit enabled
Reply 16 of 32, by CoffeeOne
andy120 wrote on 2022-03-24, 20:44:
edit
oh boy.
Um61512 means 64kx8, so you cannot get 512kB cache, it would be only 256kBytes either.
Are you sure you set the jumpers correctly for any of the settings?
EDIT:
I checked your picture (where you had 8 times 32kx8 data and 1 one time 32kx8 for tag)
You have there JP5 1-2, JP6 1-2, JP7 Open
That setting is NOT existing, fits to nothing.
More EDIT:
Sorry JP5 is 2-3. So the jumper in the picture were correct, I apologize. My eyes are bad
Reply 17 of 32, by andy120
ahh, got you. so i have the second line. most of my 256's are stuffed.
Reply 18 of 32, by CoffeeOne
That looks good now! 256kb L2 cache are there, you can only get more with 4 times 128x8, but as you don't have those, keep it as it is now.
What was weird before that without L2 cache you had a speedsys value of a DX2-50. L2 cache is definitely important 😁
Reply 19 of 32, by Disruptor
Now you have your cache enabled, but you still do not know what is wrong with your other modules.
Note that you have very bad cache / dram timing. This leads to a poor performance.
