CPU host frequency
First post, by atom1kk
Hi on my new P4 board I have an option to change the CPU host frequency.
What is it exactly? the standard value is auto and line lower is "actual frequency" with 100MHz but greyed out. if I lower this value, can I also slow down the CPU for some older games? But its not the FSB or is it?
I have a P4 2.0
Reply 1 of 3, by Horun
Yes it is likely for FSB and you probably could slow the bus down to 66Mhz.
What exact make / model motherboard is it ??
Reply 2 of 3, by atom1kk
its an Asrock P4i45 GV. The lowest value is 50mhz I can go down. So theoretically i could slow it down to 1 GHZ?
interesting is, that the board has no 12V connector. only the big 20pin one.
Reply 3 of 3, by rasz_pl
You can only go lower? usually you would want to go up for OC 😀
P4 FSB is quad pumped, so 100MHz = effective 400MT/s https://en.wikipedia.org/wiki/Quad_data_rate
yes, lowering this will slow down CPU
