First post, by Scythifuge
Scythifuge
Offline
- Oldbie
Greetings,
In the never ending search for an all-in-one display solution for MS-DOS games and modern games, I bought this TV as I read that Freesync may be an answer for people looking to play MS-DOS games at 70Hz. I can't find much information, however. Under Windows, the capabilities are from 24Hz up to 120Hz, though it jumps from 60Hz to 100Hz in the list. I am considering an OSSC or some other VGA-to-HDMI adapter solution so that I can connect both a real P-III and 486 PCs to this TV, and I will also be utilizing DOSBox and 86Box.
Will this TV work for what I am trying to do? Is there anything else I should consider; some other software or hardware?
Many thanks!
Scythifuge
