First post, by voodoo5_6k
Hi there,
I know, we've had it many times in the past. However, I wanted to fiddle around a little and as a result, I added the scalers normal4x, normal5x and normal6x to the current DOSBox SVN revision 4473, and compiled DOSBox SVN for myself. A little experiment, I want to look into normal3x/normal6x vs. openglnb on the system I now use for DOSBox etc. It has a 2560x1440 display, and I want to check what config looks best on it for my games (all either 320x200 or 640x480, hence normal6x or normal3x respectively to reach 1920x1440).
Anyhow, I thought I'd upload the patch here, in case somebody finds a use case for this.
END OF LINE.
