circuit board work
First post, by chris2021
I have artwork for an old project. Being I don't have the actual printed representations, rather magazine pdf reproductions, the quality of the resulting printed masks could be better, I'm sure. So what I figured I have to do is import the images into some kind of program, recreate traces where needed, replace pads with cleaner versions, etc. Any suggestions as to what I could use?
The boards are in the April and May 1987 Radio Electronics.
Reply 1 of 2, by waterbeesje
Probably not the most convenient program for n00bs, but autocad canattach / import pdf. With the raster design option you can even import lines from JPEG images.
Stuck at 10MHz...
Reply 2 of 2, by zyga64
Inkscape seems to have something to offer:
https://www.eevblog.com/forum/chat/scanning-p … olu5#msg3129490
https://hackaday.com/2013/11/15/recreate-a-pc … r-and-inkscape/
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
