First post, by serjG
Hello!
I recently built a Windows 98 machine, but I've encountered an issue with my SB Live. SB16 DOS emulation doesn't work at all.
I tried installing different DOS drivers, as well as messing with autoexec.bat and config.sys. No matter what, I can't get sound working in DOS games.
My specs:
AMD Athlon XP 2600+ @ 1.9GHz
512MB DDR1 @ 333MHz
ASRock K7S41GX motherboard
ATi Radeon 9550
80GB WD hard drive
Sound Blaster Live! (CT4830)
Windows 98 SE
Reply 1 of 5, by Stretch
If you enable the LPT port in the BIOS you should be able to enable LPT sharing in the sb emulation dialog in device manager. For my AudioPCI, I have the LPT port on 378 and normal mode.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - Cubilux 7.1 USB
Reply 2 of 5, by serjG
Unfortunately, I don't see sb16 emulation in device manager.
Reply 3 of 5, by Gmlb256
In Windows make sure that the VXD drivers are installed or the SB16 emulation won't appear in device manager. A normal installation will use the WDM drivers by default which are crap. Phil's review on SB Live! could help you there.
Reply 4 of 5, by DonutKing
I had a similar issue with this card.
I found that SBEGO.exe would play the wav and fm sample fine but couldn't get it to work in most games. Eg tyrian, alien carnage.
I tried various driver versions but never had much luck.
From what I gather the sb16 emulation 8snt perfect and if you really want full DOS compatibility you should put an ISA card in alongside your Live.
Reply 5 of 5, by serjG
Hello again! I appreciate your responses, but no matter what I tried, I couldn't get SB16 DOS emulation working on my Athlon XP machine.
However, I recently got a Socket 478 system with a Pentium 4 Prescott @ 3 GHz and an ASRock P4i65G motherboard.
This time, SB16 DOS emulation worked no issues with the same Sound Blaster Live (CT4830) sound card. All I did was install the VXD drivers.
My guess is the SiS 741GX chipset my Socket A board uses doesn't cope very well with sound cards trying to emulate DOS sounds.
