Corridor 7 digital sound
First post, by FioGermi
Could just be my floppy copy, but does anyone know what triggers Corridor 7 Alien Invasion to have garbled digital sound? Corridor 7 needs lots of conventional memory in order to access its full screen mode. I run MEMMAKER on all my fresh DOS installs and that seems to free up enough memory. However something about the process upsets Corridor 7 because all the digital sound gets garbled. The game also seems to run a bit weirdly and level loading times are strangely longer. If i do a clean boot, digital sound will work fine but because there is not enough free conventional memory, full screen mode will not be available. (It will only let me go up to full screen w/ statusbar).
I'm not really a config.sys/autoexec.bat wizard. I assume something memmaker does is upsetting the game but i'm not 100% sure what. I have SmartDRV rem'd out to free up more of my 16mbs of ram but that is all i change after running memmaker.
