First post, by Gary.H
As per the title.
I need a HSF for my AMD 5x86 - 133 but the Socket 3 on my Shuttle Hot 433 doesn't have the two centred tabs (as shown below)
240.39 KiB
...so I can't use a Socket 7 HSF with the central clip 🙁
My Socket 3 also doesn't have the four recesses to accommodate a clip-on style HSF (as shown below) so I can't use a clip-on HSF because the clips cause the CPU to sit so proud of the ZIF socket that the pins don't make proper contact 🙁
210.01 KiB
Since my Socket 3 only has the offset tabs (see below) I assume I need a HSF that attaches with the Z-shaped wire ?
    39.29 KiB
Reply 1 of 18, by heckyeah
Yup, either that or a heatsink with plastic clips that attact directly to the sides of the CPU.
You can find a Z-clipped heatsink on Ebay still if you search for "Cooling Heat Sink CPU Pentium P75". They might collide with mobo parts sometimes but I've used them on socket 3 boards as well.
Reply 2 of 18, by FioGermi
There are these little heatsinks that just clip onto the sides of a 486 CPU. You should be able to find those on Ebay. Or, I'll let you in on my super secret:
Be lazy! Buy a roll of thermal tape on Amazon and stick whatever Socket 7/small heatsink you already have lying around onto the CPU. I do this all the time and its worked out just fine.
Reply 3 of 18, by Gary.H
Thanks for the suggestions but I already have a clip-on style HSF. The plastic clips cause the CPU to not sit flush on the ZIF socket (because my Socket 3 doesn't have the four recesses to accommodate the protruding clips), so much so that the CPU pins don't look like they're going into the socket far enough 🙁
Reply 4 of 18, by FioGermi
Gary.H wrote on 2022-04-20, 16:26:
*pulls out roll of thermal tape*
You know what to do
Reply 7 of 18, by TheMobRules
If you're worried about damaging the writing on the top of the CPU I would suggest 3M thermal tape, it provides a secure bond but in case you need to remove it you won't have any issues as it is very elastic and does not leave any marks.
Another option would be to get one of those 486 coolers which used a plastic frame to hold the heatsink in place, but those are not as common as the clip-on variant.
Worst case scenario you could jury-rig a Z-clip using a paperclip or something like that.
Reply 8 of 18, by Gary.H
From this thread Can anyone recommend a cooling solution from Amazon for an AMD 5x86?
it looks like the clips on my clip-on HSF are way thicker than they need to be. The one shown in the thread has much shallower clips.
Reply 9 of 18, by Gary.H
TheMobRules wrote on 2022-04-20, 16:43:
Thanks - I bought the cheapy heatsink with the Z-shaped wire to use temporarily and to see if I can use the wire clip on the P75 HSF (central clip) that I have.
Reply 11 of 18, by waterbeesje
I've used 3M carpet tape before on a DX2 5v CPU, with regular size sink and fan. It conducts enough heat to keep the CPU cool enough to remain comfortably warm. Can't imagine the 3,45v 586 runs much warmer...
Stuck at 10MHz...
Reply 12 of 18, by Solo761
If you have 3D printer and a bit of patience for 3D modeling you could make plastic clip that uses these offset tabs.
I did similar thing with Pentium cooler, retainer clip on cooler broke in half so I modeled and 3D printer plastic one. Surprisingly it works fine 😁. Made a "hole" in the middle for M3 nut and screw so when I install it I can turn the screw in to create pressure on middle of the cooler. Maybe better to sketch it quickly in paint instead of describing 🤣
2.95 KiB
Works pretty good. It could be easily scaled to Socket 3, only potential problem would be if cooler had slot for retainer clip or not.
If it doesn't it would probably bet better to go with some of the designs douglar posted.
Reply 13 of 18, by Tetrium
Gary.H wrote on 2022-04-20, 16:01:
As per the title. […]
As per the title.
Yes, you will then need to get a heatsink which can accommodate the z-shaped wire.
Be aware that more modern heatsinks often have a thicker base, which makes using the z-shaped wire harder or impractical unless you can manage with some bending. Also your AMD 5x86 probably probably won't need such a beefy heatsink anyway.
I can relate to not wanting to use glue or tape. For me it's mostly about it being less secure (if it falls off for some reason (age or because it's crummy quality or whatever), I will never notice until it's too late).
My retro rigs (old topic)
Report spammers here!
Reply 14 of 18, by Cuttoon
Gary.H wrote on 2022-04-20, 16:33:
Found one Cooling Heat Sink CPU Pentium P75 on eBay with the Z-shaped wire but it was only the heatsink.
Good grief, are you being serious?
You might just have to bite the bullet there and get a 50 x 50 fan as well and screw it on top of that heatsink, how about that? You do own a philips screwdriver?
Or, yes, use the Z-clip on some other cooler - so you do have screwdriver?
In any case, feel free to use your imagination as long as that's still legal in your country. 😉
I like jumpers.
Reply 15 of 18, by Gary.H
Cuttoon wrote on 2022-04-21, 12:57:
No attachment points on that cooler to accept a fan (regardless of screwdriver ownership) so the point stands.
Reply 16 of 18, by frudi
Gary.H wrote on 2022-04-21, 16:32:
Of course you can use screws to attach a fan to that cooler. The screws will push their way in between the fins of the cooler, forming a secure grip. Something like 5x15 mm self tapping screws should do the job just fine. If your screws are thinner than the spacing between the fins, just simply squeeze the fins closer together until the screws grip against them.
Reply 17 of 18, by Cuttoon
Ah, I see. Many did not back then. Just use the usual coarse threaded screws around 25 x 4 mm. They will bite into the side of the fins, aluminium being rather soft, making their own threads.
I like jumpers.
Reply 18 of 18, by Tetrium
It was actually quite common back in the day to simply place the fan on top of the heatsink, put a screw (that's long enough) in each hole and just screw it onto the fins 🙂
