First post, by Paar
I have ordered Asus P2B-B motherboard which expects USB/MIR expansion card to access USB and PS2 ports. I have such a card but unfortunately without a PS2 connector, so I'd like to add it myself. It should be easy enough, one needs to solder the rest of the pins, get hold of a 18pin cable and then solder PS2 connector with some inductors/capacitors. But I don't know the values of the latter and instead of guessing I'd like to ask if there is somebody who has such a card in it's complete form and if it would be possible to make some measurements?
I don't plan to solder IR connector as I won't be using it.
    114.83 KiB
    Asus USB/MIR without PS2 connector
