First post, by terryfi
Hello everyone,
I have a Pentium 4 computer with Asus P4B266 motherboard. It works without an issue with an IDE hard drive but when I use IDE2SATA adapter, image attached, it detects hard drive and read/write to it but it won't boot from it.
Is anyone familiar with this incompatibility or issue? I am thinking of using adapters with other chipset but they are considerably more expensive.
    87.67 KiB
Reply 1 of 6, by chiveicrook
While I haven't used this particular type of adapter, once the drive is detected in bios it usually should boot without a problem which is why I believe the problem lies elsewhere. What's on the drive that you are trying to boot? Can you force boot with a boot manager (for example plop boot manager)?
Reply 4 of 6, by weedeewee
try doing new install on empty (no partitions/data) drive attached to ide2sata
Do not ask Why !
Reply 5 of 6, by terryfi
weedeewee wrote on 2022-05-02, 16:40:
I found the issue clean installing xp; empty drive it installs on reboot it wont boot from it goes back to xp setup.
Reply 6 of 6, by weedeewee
any chance of trying with windows 98 ?
Do not ask Why !
