First post, by Y2KBazo
- Newbie
hi!
i have an ibm 380D that wont boot due to a 1201 error. (serial b/ir faliure) the F1 trick will not work as well.
there is a tool to disable that port at the BIOS level but since i cant boot i cannot use it.
there is a great thread where someone has the same issue on a 600 and they show what values to change on the BOISes built in hex editor to disable ir but this wont work for me most likely because i have a different model and bios rev.
https://thinkpads.com/forum/viewtopic.php?t=97950
was wondering if anyone knew the values to change on a 380d or if they could run PS2.exe or something of the sort on theyre own 380d and copy the values it changed.
ive got a 380d with bios rev 1.23
thanks!
P75 on SIS 5511, 16MB EDO, Trio 64V2, SB16 CT227
P200 MMX on Triton ii, 64MB EDO, Rage pro + Voodoo, AWE64
PIII 1000 @ 140FSB on 694X, 512MB SDR, GF2 TI, Live CT4760
Smelleron 1200 @ 117FSB on 694T, 1 Gb SDR, FX5600U
