First post, by ciornyi
Hey retro community
Im just curious because i never installed DOS in proper way and more likely i will never get a chance to get copy . Maybe only if MS decide to make "remaster " versions as they do with games analogy.
DOS/95: PII266/128mb/AWE64/TNT
Win98: P3 900/256mb/SB live/3dfx V3
Win Me: Athlon 1333/256mb/Audigy2/Geforce 2 GTS
Win XP: E8500/2GB/SB X-fi/HD6850
Reply 1 of 12, by SScorpio
If you mean doing a full install versus just copying files off a boot floppy. Then the full install will include a bunch of utilities that helped the usability of the system back when it was the primary system someone used.
If you are only booting to DOS for games, then you probably won't see much benefit.
Reply 2 of 12, by Gmlb256
SScorpio wrote on 2022-05-07, 18:49:
This.
It also includes a help file containing detailed information around the commands and utilities that came with a proper DOS installation.
The close thing to "remastering" the actual MS-DOS would be waiting for Microsoft to release the source code for later versions and building the components from there.
Reply 3 of 12, by cyclone3d
The original disks pop up on eBay all the time.
And there are other places to get disk images for recovery purposes.
But if you are copying DOS off a machine that has all the files, then there is no real need to have original install disks.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 12, by davidrg
If only someone could have tweeted microsoft into open-sourcing DOS 6.22. But even if they did there are a bunch of things licensed from 3rd parties they couldn't open source. I think Memmaker or some part of it comes from Helix, MSAV and probably some other bits from Symmantec, DoubleSpace from Vertisoft. Though I guess they could release the encumbered bits as freeware and opensource the rest.
I'm kind of surprised that the price of MS-DOS 6.22 on ebay is higher than almost nothing but for someone with US$ to spend who doesn't live on the other side of the world I don't imagine its expensive to buy. You should be able to get it as an OEM bundle with Windows for Workgroups v3.11 (11 disks IIRC) which may better value for money. There doesn't exist a regular retail version of DOS 6.22 - only the upgrade box which I'm not sure you can install on a blank hard disk.
Reply 5 of 12, by Sunoo
davidrg wrote on 2022-05-07, 22:43:
F3 to exit the installer, sys c:, restart the installer.
Or just buy the OEM version.
Reply 6 of 12, by chinny22
Unless I'm after the complete feel of Dos/Win3x PC I prefer the cut down method of format c:/s then copying the very few files needed for a retro gaming rig .
99.9% of the files dos installed are no longer needed on a simple gaming PC.
Reply 7 of 12, by cyclone3d
MS-DOS 6.22 upgrade was free from MS via their old FTP server.
As long as you have MS-DOS 6.0, then you can do the 6.22 upgrade for free.
In addition to that, there are ways to install the 6.22 upgrade without having 6.0 in the first place.
I forget the exact steps as it has been a while since I did that but I could write up some instructions when I get the time and if I remember.
YMF7x4 Guide
Reply 8 of 12, by Sunoo
cyclone3d wrote on 2022-05-09, 17:10:
I wrote them two posts prior.
Reply 9 of 12, by Intel486dx33
I just boot off a bootable DOS floppy with CDROM support.
Then fdisk and format the C partition.
Then I copy everything on the bootable floppy to the C drive.
# A:\xcopy *.* c:\
And last Sys the C drive
# sys c:
Reboot.
Reply 10 of 12, by cyclone3d
Sunoo wrote on 2022-05-09, 17:59:
Hah... I fail at reading. Thanks.
YMF7x4 Guide
Reply 11 of 12, by Cyberdyne
All DOS is copyable. Hey all non NT Windowses before 95 are also just copyable.
