First post, by Babasha
Hi!
I need help with identification of lost voltage regulator on INTEL AA-654850-206 Advanced/ML Marl motherboard.
I highlight it position with the red on picture. Maybe it CS5702-1?
Tnx!
Need help? Begin with photo and model of your hardware 😉
Reply 1 of 21, by dionb
Can't help with the transistor, but can help you with the name. That's an Intel Advanced/ML "Marl" board. Perhaps you can find more with that, or others with the same board might recognize it easier.
Reply 2 of 21, by debs3759
It looks like it's the voltage regulator you need. See page 7 of https://www.ultimateretro.net/motherboard/man … 21179229398.pdf to confirm this.
Reply 3 of 21, by Babasha
debs3759 wrote on 2022-05-18, 19:54:
Yep! So i need a photo with readable part number of this voltage regulator.
Reply 4 of 21, by snufkin
With a decent photo of the front and back of the board in the area around the regulator then it might be possible to work out how it's wired up, and from that have a guess at what the part ought to be. Only worth trying that if no one else can find out what the part really is.
Reply 7 of 21, by Babasha
quicknick wrote on 2022-05-19, 22:08:
I have a late replica of this board, made by InBus Engineering (aka "the world's largest supplier of retired Intel Motherboards and systems.").
The vrm is a LT1585A.
Great! Thank you!
Reply 8 of 21, by Adriand1281
Hi. I have the same problem, but I need the second line from the layout to identify this element. It'll probably say "ACT" there, but I'd like to be sure. If you could take a peek to clear my doubts. Thank you in advance
Reply 10 of 21, by majestyk
Adriand1281 wrote on 2022-08-19, 19:08:
There are only 2 versions of this regulator: one with adjustable output voltage (LT1585ACT) and one with 3.3V fixed (LT1585ACT-3.3).
https://www.analog.com/media/en/technical-doc … ets/1585afa.pdf
(Some manufacturers use the "ADJ" marking for the adjustable version).
As far as I understand the manual the board is for 3.3V CPUs only so I assume it´s LT1585ACT-3.3.
To make 100% sure you can check if pin 1 of the regulator is connected to ground. If so, -> LT1585ACT-3.3
Reply 11 of 21, by Adriand1281
majestyk wrote on 2022-08-19, 20:13:
There are only 2 versions of this regulator: one with adjustable output voltage (LT1585ACT) and one with 3.3V fixed (LT1585ACT-3 […]
I will check the short to ground on leg No. 1. And I have one more question. This stabilizer is quite hardly available and I would have to order it from China, is it possible to use a replacement or impulse converter there? As you think, at least for testing.
Reply 12 of 21, by majestyk
You can use any pin-compatible 5A regulator with either 3.3V fixed or variable output, but then you need to add 2 resistors (and cut the ground-connection) to adjust to 3.3V.
For testing purposes - only - you can connect the regulator output-land directly to the 3.3V line at the PSU connector.
There might / will be stability issues, since the PSU output isn´t regulated as precisely as the integrated regulator and there´s a longer wire involved which incurs resistance and inductivity and this opens the door for transients and instable core voltage.
Reply 13 of 21, by Adriand1281
majestyk wrote on 2022-08-22, 11:20:
Thanks for the advice, good idea. It is about a few seconds with a diagnostic card plugged in whether the wogule bios will react and any POS codes will appear. Thank you for your help, I'll let you know if the board responds.
Reply 14 of 21, by Adriand1281
After connecting 3.3v, the board fired without any problem. However, I have doubts whether this is just a 3.3v regulator and not an ADJ. Pin No. 1 is not directly connected to ground. I took pictures of what it looks like. There is also a capacitor missing, but it is probably just filtering. How do you think it will be a standard 3.3V LT1585ACT-3.3 (I could track it in a country shipping store, but I don't know if it should be inserted)
231.19 KiB
502.71 KiB
484.18 KiB
Reply 17 of 21, by majestyk
Then it´s safe to say it´s NOT the fixed version, but the adjustable one.
Does any of the resistors ( 2 x 127 ohm, 1 x 100 ohm) have zero ohms to the regulator output pin? (You need to disconnect the 3.3V bridge wire for measuring.
94.83 KiB
If the 2 x 127R were parallel, R1 would be 63.5R
With 100R (the blueish one) as R2 we would have 3,22V at the output.
Reply 18 of 21, by Adriand1281
majestyk wrote on 2022-08-24, 13:44:
Then it´s safe to say it´s NOT the fixed version, but the adjustable one. […]
One of the 127 ohm resistors is shorted to the output of the stabilizer. If I understand correctly, it is enough to slide all elements from this track and make a jumper to ground? My only concern is that this line goes further to some transistor. What do you think about cutting the path and making a jumper in place of the missing capacitor? I wouldn't have to remove the thread from this line, and the stablilizaror would have a short to ground.
Reply 19 of 21, by majestyk
We don´t know what´s connected to pin1 in some layer inbetween. Cutting visible traces might not be enough. You could also bend pin1 upwards so it won´t come near the landing on the PCB and make a wired connection to ground, if you want to use the fixed regulator version.
I would go with the adjustable version. If R2 is 200R (have you measured in both directions?) and 127R goes to Vout, you´re fine.
[(200/127) + 1] x 1.25 = 3.22V
You would keep the possibility to select different core voltages in the future if needed.
