AdLib GOLD clone is now a reality
Reply 81 of 199, by 640K!enough
GL1zdA wrote on 2022-10-20, 06:24:
What is the fastest CPU known to work well with the Adlib Gold?
Decades ago, I had an official response from a support person at Ad Lib Multimedia. He said that, depending on the software and particular configuration, many 486 systems didn't respect the necessary delays for the Ad Lib Gold 1000, particularly at or beyond 33 MHz.
His response aside, practical experience tells me that there are some types of 486 motherboards that won't work well unless very carefully configured, particularly those with many bus timing options. This was common on inexpensive SiS-based VLB boards; some of them didn't offer the timing options via the BIOS setup, and couldn't easily be made to work at all. However, with a decent board, careful configuration and decent software, I have had the original card running on Socket 7-era boards, and even some from the 440BX era.
Never under-estimate the need for well-behaved software. Remember that this was one of the first software-configurable sound cards, and it was designed when 8086, 286 and 386SX systems were most common. Some software didn't really work too well, and would modify the configuration, instead of reading it, thereby creating a conflict, just before trying to play audio (with predictable results). Other software has such sloppy timing routines, that getting it to work at all is an exercise in frustration.
In summary, a mid-range 386DX is probably the sweet spot for this card. Too much slower, and there may be problems getting clean playback at 44.1 kHz stereo. Too much faster, and you start playing bus-timing and delay-routine roulette.
Reply 82 of 199, by keropi
oh that is very useful info 640K!enough , thanks for sharing!
I will add this info in the goldlib site as it is important info
I had no idea games could alter the card's configuration, that is a weird side-effect!
Reply 83 of 199, by 640K!enough
keropi wrote on 2022-10-20, 20:53:
It can be quite an annoyance, and difficult to figure out, especially when you don't expect it. They usually don't also write the new configuration to the EEPROM, so a re-boot is usually enough to get everything back to normal. Getting such software to actually work, on the other hand can be "interesting", especially if you have other hardware that actually needs the resources that it tries to steal.
Reply 84 of 199, by Shponglefan
640K!enough wrote on 2022-10-20, 20:48:
This is very good information for sure.
I have a pair of 386 machines (SX-25 and DX-40) so it would be interesting to test them both out to see how the Adlib Gold behaves at these respective speeds.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 85 of 199, by bnz99
A related question: did the software with which the RL2 demo songs were created ever get leaked, is the file format known or is it in any other way possible to somehow easily make use of the mixed OPL3/PCM functionality of the Adlib Gold/Golddlib card for new music in a retro machine when coming from a modern software like Deflemask or Furnace Tracker?
Reply 86 of 199, by GL1zdA
Thanks for this answer. Do you remember which timing options have you used for the Socket 7 and 440BX boards? Were the socket 7 boards Intel Triton based, or have they used some 3rd party chipsets?
getquake.gif | InfoWorld/PC Magazine Indices
Reply 87 of 199, by 640K!enough
GL1zdA wrote on 2022-10-21, 06:09:
Given the wide variety of boards, getting this to work will be a process of trial and error; probably a frustrating one. I don't remember much about the Socket 7 board, as it was about 20 years ago. I do remember that it was a 430VX-based board from a company commonly called m-Tech (officially M Technology, Inc.). I don't remember anything about its settings.
The 440BX-based board I still have and use. Getting it running here can be somewhat tricky, depending on your configuration. Absolutely do not try to run the ISA bus out of specification in any way; standard timing/clocking options only, if you have them. You will have to increase the 8-bit I/O Recovery Time close to as high as it will go. On my board, this has to be at least 4, or I get only awful noises. You will also have to experiment with Delayed Transaction and Passive Release to see which combination yields the most stable results.
It is also important to point out that some other cards won't be able to work under these conditions. For instance, the InterWave sometimes doesn't like having "too much" I/O Recovery Time, so they won't co-exist too peacefully. If we're talking specifically about the GoldLib (clone), given that it doesn't contain a genuine Ad Lib control chip, I don't know how close the timing is, compared to the original. This may change the behaviour slightly, and may require somewhat different settings.
Reply 89 of 199, by keropi
Megadragon15 wrote on 2022-10-21, 16:08:
Have you checked out Ebay lately? Someone from Canada has listed two separate auctions for add-on modules to the Adlib Gold 1000: a cd-rom interface and a SCSI interface.
I have not seen it and I cannot find anything related
so at least the cd-rom addon was released then? I had no idea - would be interesting to see what kind it was!
Reply 90 of 199, by JimWest
Can you please send a link? Unfortunately I am not able to find that listing.
Reply 93 of 199, by GL1zdA
I'm adding the photos here, since they vanish from eBay after some time. None of these looks complicated, I guess the "interface" pins of the AdLib Gold are just a subset of ISA pins, probably the only thing Adlib is doing is managing resources. There were sound cards that had a socket for an NCR chip, AdLib and later MediaTrix loved daughtercards. These will probably sell for an insane amount of money and I doubt buyers will be interested in sharing them for reverse engineering, though as I said, they don't look too complicated.
    203.89 KiB
    AdLib CD-ROM Interface - Back
    223.42 KiB
    AdLib CD-ROM Interface - Front
    152.61 KiB
    AdLib SCSI Interface - Back
    162.64 KiB
    AdLib SCSI Interface - Front
Reply 94 of 199, by Shponglefan
That SCSI adapter already has a bid price of $400 CAD. That does seem a bit excessive, but I guess these are more about the collectability than practicality (which arguably applies to the Adlib Gold as a whole).
Reply 95 of 199, by vetz
Shponglefan wrote on 2022-10-21, 19:12:
Only the imagination is the limit here.
I'd compare this to the memory module for the 3D Blaster VLB, if that ever got on Ebay, it's all about that collectability!
Reply 96 of 199, by keropi
I wonder if both these interfaces actually work - at the very least they would need a newer set of drivers
especially the SCSI adapter is rev.0 , that 0 is prototype-land number
Reply 97 of 199, by mr.gravis
is there driver support for windows?
is it possible to record a guitar through the microphone output? I mean through a dynamic microphone. I understand that there are better ways to record, but here I'm talking about nostalgia
nostalgia, nostalgia and nostalgia again
Reply 98 of 199, by Pierre32
mr.gravis wrote on 2022-10-24, 19:37:
User guide, driver info and everything else you want to know is on the site: http://pcmidi.eu/goldlib.html
Reply 99 of 199, by keropi
I will add the drivers to the site as well - nothing the world didn't already see though
there is also this nice archive -> https://archive.org/details/adlib-gold-users-guide
it even comes with recordings
If anyone has a nice structured drivers archive and wishes it to be mirrored on goldlib's site do tell me about it 😀
also 1st batch is now sold, 2nd and final one will be made available in due time (because it's REALLY a time consuming work...)
