First post, by Tempest
I have a weird Six Pack clone that says Multitech MFB-PC on it. I can't find any information on it, much less a diagram for the switch settings. Can anyone point me in the right direction or tell me what the appropriate switch settings would be for a 640KB IBM 5150? What its set to right now seems to work, but I'm not sure if it's actually correct or not.
The reason I ask is that my system seems to be crashing a lot lately and I'm wondering if it's this card or something else that's amiss like the power supply.
http://atariprotos.com/temp/mystery.jpg
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 1 of 6, by Horun
Sorry a quick search gave no documentation or any other pictures of similar Memory+IO card...
Just guessing: SW1 is the memory size and starting address, SW2 is for the Serial and Parallel ports.
Can you post a picture of the back of the card ? I had to decode switches on a few things before and have been fairly lucky.
Reply 2 of 6, by Tempest
Horun wrote on 2022-05-28, 23:00:
Sure here you go:
http://atariprotos.com/temp/mystery2.jpg
I'm not using the serial or parallel port part of the card so I'm not worried about that. Of course if I have the card set to use them and they're not attached then maybe that's causing my problem? It's got to either be this card or my power supply.
No one seems to have any info on this card. All I've been able to find out is that Multitech changed their name to Acer after a short time.
Reply 3 of 6, by Horun
Thank, I will try to figure out a bit later after chores and dinner with the family.
Yes it seems lot of older Multitech stuff disappeared and Total hardware barely covers anything they made.
Reply 4 of 6, by Tempest
Horun wrote on 2022-05-28, 23:39:
Thanks, I really appreciate it.
Reply 5 of 6, by Horun
Don't get your hopes up. Just did a quick front - back image compare and appears there could be a hidden layer of the PCB with some signal traces that cannot be easily followed.
Will give me something to look over for the next few days... like puzzles 😀
    603.76 KiB
